Sony STR-DE197 power Polk Audio Monitor 70 and PSW110
New2Music
New2Music Posts: 7
I currently own a Sony STR-DE197 receiver. Would this be sufficient to power the Polk Audio Monitor 70's? I read that you can blow speakers from underpowering them and rather not waste $400+.
Also, I know this is not usually recommended, but can I wire the receiver to the PSW110 to the 70's? I would rather not have to buy a new receiver, but if that is the only way, any suggestions?
Post edited by New2Music on
  • New2Subz
    New2Subz Posts: 3
    edited March 2011
  • New2Music
    New2Music Posts: 7
    edited March 2011
    Thanks, you too!
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    The monitor 70,s are not that difficult to power, you should be fine. I had my monitor 70,s powered by A SONYES5300, they sounded great. You have a " smaller" receiver however the monitor series are not that difficult to power. FYI the 70,s sounded a lot better when I added an amp..........................
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • New2Music
    New2Music Posts: 7
    edited March 2011
    slk55amg wrote: »
    Thanks slk55amg! What amp do you recommend/use?
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    I have an Emotiva XPA5, it powers everything with ease, my rear surround speakers ( FXI3,s) are powered by my ES5300.
  • New2Music
    New2Music Posts: 7
    edited March 2011
    Thanks. Sorry I missed that in your signature. I guess I will start having to save up for that beauty!
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    EMOTIVA, has an end of year sale, the current price for an XPA5 is $899, on sale it will probably be $799, you have plenty of time...........
    edited March 2011
    That Sony will run your M70s--just don't PUSH It because the 70s will and can clip that Receiver, so don't try to blast your neighbors out.
    As far a I can see that Sony has no SUB pre-out for a line to your sub.
    What you would need to do is wire the sub directly to the B terminals using the High Level Inputs on the Polk sub (I assume it has those). Then you would run both A + B speakers (the A would be wired to the M70s, the B to the sub). Use the sub's crossover to adjust the Frequency cut off!
    And Enjoy!
    cnh
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    FYI, if you decide on an amp in the future, you will need a receiver with pre/outs, I am unsure if your current Sony has them.
  • New2Music
    New2Music Posts: 7
    edited March 2011
    Thanks for your help cnh and slk55amg (again)!
    cnh - to make you I understand you and don't break anything, is this correct?
    43To69A
    edited March 2011
    That's IT....I know using words is not as good as the diagram you've made above. Should probably have this as a 'sticky' for others with similar questions.
    cnh
  • New2Music
    New2Music Posts: 7
    edited March 2011
    How do you make a sticky?
    edited March 2011
    Usually, the Moderators do that. Don't worry...I'm just suggesting it here so that a staff person might consider it!
    cnh
  • New2Music
    New2Music Posts: 7
    edited March 2011
    Gotcha. Thanks for your help!
