Signal cable or Blue Jeans
bdtae5656
bdtae5656 Posts: 235
Im looking to purchase a new pair of interconnections either SC's Analog one or two or Blue jeans LC-1. What does everybody think?
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited March 2011
    Look for used Signal Cable II's, they can be had for the price of new SC A I's....well that's what I've always sold/bought mine for.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2011
    Both companies make good wire you can't go wrong with either one. I chose BJC for the easy connectors & lower price.
  • janmike
    janmike Posts: 6,146
    edited March 2011
    Agreed, both good. I use SC in my HT.
    Michael ;)
    NORTH of 60°
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2011
    The terminations are better on the Signal Cable.
  • Willow
    Willow Posts: 11,231
    edited March 2011
    kawizx9r wrote: »
    http://www.polkaudio.com/forums/showthread.php?t=117324
  • shack
    shack Posts: 11,154
    edited March 2011
    I am a big fan of Signal Cable. Great product, great service & good price (not the cheapest...but well worth the price IMO).
  • dragon1952
    dragon1952 Posts: 4,907
    edited March 2011
    Since I'm retired and have nothing better to do at the moment, I'll break it down a little.
    The Signal Cable Analog I's are pretty high capacitance compared to the Analog II's or Blue Jean LC-1's.
    Analog I - 28.5 pF/ft
    Analog II - 17.3pF/ft
    LC-1 - 12.2pF/ft
    From the Blue Jeans website:
    "Capacitance contributes to high-frequency rolloff, so the lower the capacitance of the cable, the flatter the frequency response in any given application (how flat will depend on the device impedances as well as the capacitance, so it's not possible to generate a one-size-fits-all frequency response chart; but in every case, the lower the capacitance, the flatter that curve will be). Capacitance, like many cable attributes, is a per-foot characteristic; while high capacitance won't ordinarily make a significant difference in short runs, it becomes an increasing problem with longer runs."
    All three use Belden made cable. The Analog II uses a 22AWG bare copper stranded center conductor, whereas the LC-1 uses a 25AWG solid copper conductor. Both have a very similar dielectric and shielding with the LC-1 offer a little more braid coverage (98% vs 95%). The Analog I uses an 18AWG copper coax conductor of some kind but they don't go into much detail past that. I think the Analog II uses Belden 89259 which is a RG-59 type video coax which has been a pretty popular cable for audio IC's. The LC-1 is supposedly made by Belden for Blue Jeans Cable to their specs and is designed for audio.
    Depending on several variables, I would think the Analog I's could have a tendency to potentially roll off highs a little. If your system is on the bright side that might be OK, whereas the LC-1 with it's ultra-low capacitance could potentially make the same system seem even brighter.
    In my tube based system I preferred the LC-1 over the Analog II, but then again my system is probably on the warm side. I don't think I've tried the Analog I.
    Comparing the price for the Analog II vs the LC-1:
    Analog II - $55 per 3ft pair minus 5%??? (they used to give Polk members a 5% discount), plus shipping. $6 per pair for each additional foot.
    LC-1 - $34.25 (with Techflex to match the Analog II spec) plus shipping. $3.50 per pair for each additional foot.
    To me that's a no-brainer.
    Analog I - $40 per 3ft pair minus 5%???, plus shipping. $4 per pair for each additional foot.
    I think the Analog II and LC-1 are both very comparable performance-wise, but are probably both much better than the Analog I.
  • Face
    Face Posts: 14,340
    edited March 2011
    The Analog II excels when used with Eichmann RCA's.
  • B Run
    B Run Posts: 1,888
    edited March 2011
    I love my Signal Cable Analog II's, they're great quality and a great company.
  • janmike
    edited March 2011
    Face wrote: »
    2nd that one.
    Michael ;)
    NORTH of 60°
  • Conradicles
    Conradicles Posts: 6,339
    edited March 2011
    I currently run Blue Jeans, but I would go with SignalCable in this price bracket. The SignalCable Ultra speaker cables are way better in my opinion than anything Blue Jeans has to offer as far as quality and appearance.
    My favorite combo is the Silver Resolution Interconnects with the Ultra speaker cables.
  • acmf74
    acmf74 Posts: 937
    edited March 2011
    What are the benefits using Eichmann RCA's?
  • Conradicles
    edited March 2011
    acmf74 wrote: »
    I think they are copper, or you can also get them in silver.
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2011
    acmf74 wrote: »
    Go read the Eichmann site. But basically, it boils down to the connector is designed to minimize eddy currents across the electrical interface between the connector and the jack
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
