How to burn in a multi channel amp
polkfarmboy
I know you have to burn in products even though I don t understand why
I have a 5 channel amp in the box and only used for 4 hours . If I am to burn the amp in then do I have to hook a speaker up to each channels and leave it on for a long time to burn it in ?
Is the sound on amps really that diff after a burn in ?
Post edited by polkfarmboy on
I've found that my NAD 765 sounded good right out of the box. Of course I was using for HT only and in my experience HT is all about sound effects. Over time the AVR did start to tone down a bit as the NAD house sound is one of warmth. As far a critical listening to music goes I haven't tested it for that but I'm sure it would need burn in to get the sublte nuances and harsh highs to become tame. YMMV and yes this is just my opinion as far as the music section goes. It can never hurt to burn-in electronic or break-in mechanical devices such as speaker drivers.
Acetyline torch perhaps?
I usually will set a cd to repeat while at work at a modest to low volume and just let it play. With a multi channel amp, I would do the same, but load a dvd instead and just turn off the tv.:cool:
As far as speakers are concerned, I would hook up all channels.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
There is no burn-in for solid state electronics or cables. It is a myth.
Dragons and mermaids are a myth. Burn in may be subjective, but real.HT SYSTEM-
lsi 9's -
That you know what you are talking about is also a myth.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'll leave the audability of "burn in" debate to others but know the above quote to be factual.Factory burn-in of equipment is used to determine those units that have premature component failure. -
I dont know if "burn in" is real or not, but if it is real, I've got that covered. The last two amps I bought are each over a decade old.Do you hear that buzzing noise?
Quote:
You're full of crap and that's no myth.Political Correctness'.........defined
President of Club Polk -
Oh good grief, just hook it up & play it. The burn in if there is any will take care of itself while you are enjoying the tunes.
The whole lot of you need to see your doctors for undiagnosed OCD. Not everything has to be a frickin production!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Post of the year candidate? Perhaps. (fist hitting chest) Much love Cathy, some of us still get 'it'.
Cheers,
Yes Cathy, that is a good one.Michael
NORTH of 60° -
Great post Cathy! Sit back & enjoy the music is just what the doctor ordered. No need for all the fussing over technical gibberish.
It's interesting to note note that many high end electronic manufacturers recommend a burn-in period , Spectral, MIT, just to name a couple. As a matter of fact the design engineer of Spectral products once told me that the reason they don't put power switches on their products is so that the unit stays on all the time. Also he told me that after the unit has been powered off for some time to power it up and give it atleast 45 minutes for the components to stabilize.
+1000..........000....000000000......!
Good one!
Nice post.
And congratulations on making it to the 10,000+ club.
Use each channel as an arc welder to "burn" it in.
2Ch Tube Audio Convert -
Good answer, good answer! If I was Richard Dawson, I'd kiss you. :biggrin: -
Burn in allows things like coils and capacitors to become more stable, really anything which has a mechanical aspect to it. Heat cycling is a very important component of burn in although many are unaware of that. It would be good if the amp were driving a set of speakers, otherwise some of the components in the signal path may not be exercised. It is best to turn on for awhile, at least until totally up to temperature (a few days) then turned off and allowed to go back to room temp and powered up again. Several cycles of this is much better than just leaving on for the same amount of time.
Obviously at least one member of club polk was not initially burned in properly and you can see what that leads to...
Nice post.
Thank you, I didn't even notice.
On3s&Z3r0s wrote: »Good answer, good answer! If I was Richard Dawson, I'd kiss you. :biggrin:
:biggrin: Thank you, is Richard Dawson still alive? He's got to be getting up there.Burn in allows things like coils and capacitors to become more stable, really anything which has a mechanical aspect to it. Heat cycling is a very important component of burn in although many are unaware of that. It would be good if the amp were driving a set of speakers, otherwise some of the components in the signal path may not be exercised. It is best to turn on for awhile, at least until totally up to temperature (a few days) then turned off and allowed to go back to room temp and powered up again. Several cycles of this is much better than just leaving on for the same amount of time.
madmax
Oh who cares Max. So long as it plays.
It leads to a well adjusted person who is busy enjoying her music and movies & letting the rest of it take care of itself without any thought, worry, or compulsive behavior from me!
:biggrin: Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
But we like being compulsive!Vinyl, the final frontier...
Well if it is, then take your flippin medication!
:biggrin:Whoa easy now what makes you so sure it's undiagnosed.?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Great, another thing for me to worry about doing wrong.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Monster HTPS 7000 MKII
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma
