How to burn in a multi channel amp
polkfarmboy
polkfarmboy Posts: 5,703
edited March 2011 in Electronics
I know you have to burn in products even though I don t understand why
I have a 5 channel amp in the box and only used for 4 hours . If I am to burn the amp in then do I have to hook a speaker up to each channels and leave it on for a long time to burn it in ?
Is the sound on amps really that diff after a burn in ?
Post edited by polkfarmboy on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2011
    I've found that my NAD 765 sounded good right out of the box. Of course I was using for HT only and in my experience HT is all about sound effects. Over time the AVR did start to tone down a bit as the NAD house sound is one of warmth. As far a critical listening to music goes I haven't tested it for that but I'm sure it would need burn in to get the sublte nuances and harsh highs to become tame. YMMV and yes this is just my opinion as far as the music section goes. It can never hurt to burn-in electronic or break-in mechanical devices such as speaker drivers.
    nooshinjohn Posts: 25,901
    edited March 2011
    Acetyline torch perhaps?:wink::tongue:
    I usually will set a cd to repeat while at work at a modest to low volume and just let it play. With a multi channel amp, I would do the same, but load a dvd instead and just turn off the tv.:cool:
    As far as speakers are concerned, I would hook up all channels.
    tonyb Posts: 33,069
    edited March 2011
    xcapri79 wrote: »
    There is no burn-in for solid state electronics or cables. It is a myth.
    Dragons and mermaids are a myth. Burn in may be subjective, but real.
    edited March 2011
    xcapri79 wrote: »
    That you know what you are talking about is also a myth.
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    xcapri79 wrote: »
    Factory burn-in of equipment is used to determine those units that have premature component failure.
    I'll leave the audability of "burn in" debate to others but know the above quote to be factual.
  • Monster Jam
    Monster Jam Posts: 919
    edited March 2011
    I dont know if "burn in" is real or not, but if it is real, I've got that covered. The last two amps I bought are each over a decade old.
    Do you hear that buzzing noise? :confused:
    F1nut Posts: 51,719
    edited March 2011
    Quote:
    You're full of crap and that's no myth.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2011
    Oh good grief, just hook it up & play it. The burn in if there is any will take care of itself while you are enjoying the tunes.
    The whole lot of you need to see your doctors for undiagnosed OCD. Not everything has to be a frickin production!
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2011
    cfrizz wrote: »
    Post of the year candidate? Perhaps. (fist hitting chest) Much love Cathy, some of us still get 'it'.
    Cheers,
    Russ
  • janmike
    janmike Posts: 6,146
    edited March 2011
    Yes Cathy, that is a good one.
    Michael ;)
    NORTH of 60°
  • pearsall001
    pearsall001 Posts: 5,254
    edited March 2011
    Great post Cathy! Sit back & enjoy the music is just what the doctor ordered. No need for all the fussing over technical gibberish.
  • hearingimpared
    edited March 2011
    It's interesting to note note that many high end electronic manufacturers recommend a burn-in period , Spectral, MIT, just to name a couple. As a matter of fact the design engineer of Spectral products once told me that the reason they don't put power switches on their products is so that the unit stays on all the time. Also he told me that after the unit has been powered off for some time to power it up and give it atleast 45 minutes for the components to stabilize.
    edited March 2011
    cfrizz wrote: »
    +1000..........000....000000000......!
    Good one!
    cnh
  • drselect
    drselect Posts: 664
    edited March 2011
    cfrizz wrote: »
    Nice post.
    And congratulations on making it to the 10,000+ club.:smile:
  • aboroth00
    aboroth00 Posts: 1,106
    edited March 2011
    Use each channel as an arc welder to "burn" it in. :D
    2Ch Tube Audio Convert
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2011
    cfrizz wrote: »
    Good answer, good answer! If I was Richard Dawson, I'd kiss you. :biggrin:
  • madmax
    madmax Posts: 12,434
    edited March 2011
    Burn in allows things like coils and capacitors to become more stable, really anything which has a mechanical aspect to it. Heat cycling is a very important component of burn in although many are unaware of that. It would be good if the amp were driving a set of speakers, otherwise some of the components in the signal path may not be exercised. It is best to turn on for awhile, at least until totally up to temperature (a few days) then turned off and allowed to go back to room temp and powered up again. Several cycles of this is much better than just leaving on for the same amount of time.
    Obviously at least one member of club polk was not initially burned in properly and you can see what that leads to...
    madmax
    Vinyl, the final frontier...
  • cfrizz
    edited March 2011
    drselect wrote: »
    Nice post.
    Thank you, I didn't even notice.:smile:
    On3s&Z3r0s wrote: »
    :biggrin: Thank you, is Richard Dawson still alive? He's got to be getting up there.
    madmax wrote: »
    madmax
    Oh who cares Max. So long as it plays.:wink: It leads to a well adjusted person who is busy enjoying her music and movies & letting the rest of it take care of itself without any thought, worry, or compulsive behavior from me!:tongue::biggrin:
  • madmax
    edited March 2011
    But we like being compulsive!
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    cfrizz wrote: »
    ... undiagnosed OCD.
    Whoa easy now what makes you so sure it's undiagnosed.?
  • cfrizz
    edited March 2011
    Well if it is, then take your flippin medication!:wink::tongue::biggrin:
    FTGV wrote: »
  • carwashguy
    carwashguy Posts: 131
    edited March 2011
    Great, another thing for me to worry about doing wrong.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Monster HTPS 7000 MKII
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
