Something to power the Monitor 70s.
JHucke
JHucke Posts: 9
edited March 2011 in Speakers
I have recently posted a thread about purchasing an HK3490 (120wpc) to power the 70s to which everyone replied the same thing, Its enough power. Unfortunately I have another problem, you see, I was further speculating the situation and wondered if I would ever want something more than 2.1. Reading good reviews about more HK products, I stumbled upon the HK1600 (7.1) which is only 35wpc. I have read that between the two receivers, the difference between 35w and 120w is only 5db... For some reason I find this a bit hard to believe. Any thoughts on this?
Thanks everyone
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    Are you referring to the HK AVR1600? That one is 50w x 7 and 35amps peak. Which is pretty decent for an AVR I'd guess. I'd worry more about current than watts.
    Plus I've heard the M70s are pretty efficient.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • JHucke
    JHucke Posts: 9
    edited March 2011
    PrazVT wrote: »
    I have read that 35wpc is in the HK AVR1600 manual.
  • JHucke
    JHucke Posts: 9
    edited March 2011
    My bad, I have been mis informed. I just checked the PDF file of the owners manual and it clearly states 50wpc to 7 channels. (350 watts total)
    edited March 2011
    Not a heck of alot, but then again,it doesn't cost alot either.
    The 3490 has a more robust power supply but is only 2 channels. If you think you might want a 5 or 7 channel HT down the road, look for an avr with the bells and whistles you like,and pre outs to enable you to add an amp when you may want to upgrade speakers.
