Non-Working MW65XX 6.5" drivers
    Toolfan66 Posts: 18,154
    edited March 2011
    How is this working for you anyway???
  • gdb
    gdb Posts: 6,012
    edited March 2011
    I'll have MWs till well after Hell freezes over.:wink:
    edited March 2011
    gdb wrote: »
    NICE!!!!:wink:
  • seventy1
    seventy1 Posts: 15
    edited March 2011
    gdb wrote: »
    No sell, buy only, never sell.:biggrin:
    Bummer, looks like I'll have to build a jig and go back after this thing. I tried already by shimming with the voice coil in place. Thought I had it and glued everything up only to find after pulling the shims that the coil drags. Now I need to remove the epoxy from both sides (outside, never separated) of the magnet before I try again :mad:. Any tips there? Do you glue both top and bottom sides of the magnet? My other bad driver shows 0 resistance, so there's a broken winding I suspect - repairable? I know I could just buy replacements from Polk, but I'm trying to keep these as a "thrift" purchase. Plus, I'm enjoying the journey! Thanks.
  • gdb
    gdb Posts: 6,012
    edited March 2011
    I JB Weld everything six ways from Sun. only after free/correct movement is established. No shims, no way , uh uh ! Shims are for fruiting around with cone/surround positioning.
  • seventy1
    seventy1 Posts: 15
    edited March 2011
    gdb wrote: »
    I know that now...
  • skrol
    skrol Posts: 3,456
    edited May 2011
    Hey I just picked a pair of Monitor 5B with one frozen MW-6502. Are you still interested in these? I am also in need of a working 6502.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • gdb
    gdb Posts: 6,012
    edited May 2011
    I've never messed with that MW before. Why don't you fix it and reinstall ? It's really not rocket surgery or brain science.:smile:
  • skrol
    skrol Posts: 3,456
    edited May 2011
    Ok, I probably will mess around with it, nothing to loose.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • gdb
    gdb Posts: 6,012
    edited May 2011
    Skrol, sent you a PM on repair methods.:smile:
  • skrol
    skrol Posts: 3,456
    edited May 2011
    Cool, thanks
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
