popping fx wireless
rkrupka
rkrupka Posts: 2
edited March 2011 in Troubleshooting
I recently purchased a wireless fx. I would like to know why, on occasion, the speaker emits an annoying popping sound and how I might avoid it short of returning the product.
Thank you.
Robert Krupka
Post edited by rkrupka on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited March 2011
    Hello Robert,
    Welcome to CP! We'll certainly try and solve your problem. Do you happen to have any other wireless devices in the same room? A wireless motion detecter for a burglar alarm, maybe?
    Cheers, Ken
  • rkrupka
    rkrupka Posts: 2
    edited March 2011
    No wireless motion detector. However a wireless router is about 30 feet away. A tv that uses wifi is about 10 ft away. A logitech squeezebox is about 10 ft away as is a receiver and blu-ray player. All use the wifi from the router. The tv and blu-ray are using 5GHz ,11n. The squeezebox and receiver 2.4GHz,11g. The fx transmitter is about 4 ft away from the speaker.
  • [Deleted User]
    edited March 2011
    Hello,
    The source of the problem could be one of those wireless setups. Give Polk's CS a call at 1-800-377-7655, they should be able to help.
    Good luck, Ken
