Calling all Klipsch Owners
    mhardy6647 Posts: 35,041
    edited March 2011
    Hi guys , Not being that audiophiled but went w/ the Klipsch 500 h/t SET. They're a good match for my Yamaha 665. The question is about this dude BOB CRITE and his magic xovers. Over on the Klipsch site people are raving about his work and how it changes the speakers he works on. Now I spoke to a Klipsch tech and said yes if the caps are going then replace them but these speakers were engineered w/ certain specs to begin for a reason. I pesonally still want some FortesII instead of my Infinity SM112s
    LW.....
    Sometimes :-) it seems that the approach to Klipsch speakers is the same as the folk tale known as "Stone Soup" or "Nail Broth"; it goes something like this.
    Take a (heritage) Klipsch speaker; replace the drivers with new, upgraded alternatives, replace the horns, brace the cabinet, replace the crossovers, wiring and binding posts, and add interior damping materials and they're the best speakers ever made.
  • zingo
    zingo Posts: 11,258
    edited April 2011
    You are correct in that building up your vintage Klipsch speakers can give great results. I've completely rebuilt both vintage Polk and Klipsch speakers, and I feel that Klipsch provide the most dramatic improvement with modification.
    Speaking of Klipsch upgrades :biggrin:; I just got two runs of 20 and 15 AWG solid core, PE insulated Jantzen audio cable to rewire my Fortes. I will be using the 20AWG for the tweeter horn, and the 15AWG for the mid horn and doubling up the 15AWG for the woofer. I'm not sure how much of a difference the new Jantzen wiring will make over the original 80's wiring, but at least all the internal components and wiring in those speakers will be Jantzen Audio. :cool:
  • m.afaqanjum228
    m.afaqanjum228 Posts: 5
    edited April 2011
    Klipsch has a set of forums, and there's also a Klipsch forum at www.audiokarma.org
    the little tube amps make nice nightlights,Not being that audiophiled but went w/ the Klipsch 500 h/t SET. They're a good match for my Yamaha 665. The question is about this dude BOB CRITE and his magic xovers. Over on the Klipsch site people are raving about his work and how it changes the speakers he works on.VERY good upgrade if engineered correctly. Bob Crites didn't go for price/performance,
