Ipod / Itunes sync Q
disneyjoe7
disneyjoe7 Posts: 11,435
edited March 2011 in The Clubhouse
If I got an Ipod that I'm done many CD into it, but now I like to use an computer for it. How do I get the Ipod to see the Itunes without removing all those CD's, so I can add to the Ipod?
Steve
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2011
    Can you rephrase the question, or translate it.
    Are you saying you now have an iPod that already has a number of CDs loaded on it, and you would like iTunes on your computer to recognize, and copy onto the computer, the CDs that are installed on the iPod?
    Or something else?
  • disneyjoe7
    edited March 2011
    BlueFox wrote: »
    Ok, so how do I do that?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited March 2011
    That's one of the reasons I switched to MediaMonkey and gave iTunes the boot.
    Unfortunately, (unless they have changed) that is how iTunes functions. When you sync, it wipes the device and reloads what you have selected.
    I would just re-rip the cds using iTunes, if that's what you prefer. If you want to transfer them without re-ripping, just this once- load up the free version of MM, http://www.mediamonkey.com/ you can sync FROM your iPod to your computer. Then you can add those songs to your iTunes library, and carry on from there.
    How did you get the cds onto your device in the first place? (if not iTunes)
  • disneyjoe7
    edited March 2011
    I re-rip or re-done Itunes to many times for whatever reason. I hate to do it again, that's why I asked about it.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • BlueFox
    edited March 2011
    I would guess they are trying to prevent easy file copying by people passing their iPods around and copying the songs from the iPod to the computer. I wonder if somebody has developed a shareware program to bypass that.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited March 2011
    it can be done. It requires that you have the old computer on hand and a hex editor. You'll need the itunes library files and the itunes something.xml.
    In the xml file, you'll find an id number... copy this from both old and new xml files. Open up the ittunes library.lib file (new one) with a hex editor (I use HXD) and search for the NEW id number. Replace this with the old one, and boom.. you're done.
    I do this every time I reload someones computer and they have itunes. You can do this for multiple computers, and copy music from both/many
  • disneyjoe7
    edited March 2011
    OMG, then $30 bucks for a some software to do this may be worth it.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • cokewithvanilla
    edited March 2011
    disneyjoe7 wrote: »
    it's actually really easy... here's the location of the id string in Itunes Music Library.xml
  • disneyjoe7
    edited March 2011
    Well the old computer thing is the problem.... I half built a HTPC, I'm using the old computer case, DVD, and Power supply. So motherboard, and hard drive are out and getting dust.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • cokewithvanilla
    edited March 2011
    disneyjoe7 wrote: »
    plug in the hard drive as a secondary or on usb and grab the xml file
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2011
    Or you can back the songs up, let Itunes wipe it and start fresh. You can also use Copytrans which will let you add music to it without wiping it. It will allow you to work multiple libraries as well .
  • disneyjoe7
    edited March 2011
    If I do that doesn't windows mounts drive so another computer wouldn't like that drive also?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited March 2011
    Sherardp wrote: »
    Doesn't seem like a bad program but again a $20 thing. Which maybe easier in the long run...
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • cokewithvanilla
    edited March 2011
    disneyjoe7 wrote: »
    If you plug in a drive as a secondary, it will simply load up as another drive... d.. e... whatever. This will allow you to navigate to E:\Users\[username]\My Music\Itunes and copy the itunes music library.xml
    all you need is that id number, then you just change it on the new one
  • disneyjoe7
    edited March 2011
    So I been playing a little with the idea of having my HTPC be part of my main computer. After playing with a rip CD I re-thought about this Itune stuff, I will be doing this Itunes on the older computer. I like the HTPC for any video HDMI output, but making this 2 channel also doesn't work so well. I can make the HDMI output 2 channel on the AVR but I like my 2 channnel to be working on the Conrad Johnson PV-5 pre amp that skip over the AVR. If I added a front channel audio output to the pre-amp it kills the HDMI output when watching a movie from the AVR. So making the HTPC for everything isn't a great idea.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited March 2011
    You can use a program "google it" to put the music from the ipod onto the computer.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • disneyjoe7
    edited March 2011
    I play the Ipod from the PV-5 pre-amp, which outputs to the whole house receiver from the record output of the pre-amp. I was trying to see if the computer DAC was better then the Ipod DAC. In the future I may do that with a Iport, to work the whole house receiver.
    http://www.iportmusic.com/products/in-wall/IW-20
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
