7.1 Wire Length and Gauge
Theheadsn
Ok pretty simple question, hoping for different opinons.
I know the pros and cons for monoprice wire, so the BRAND isnt really in question, more of the gauge and length.
Im going to pre wire my HT for 7.1, everything is going to be in the wall (furred wall not exterior, through metal studs, inside of either conduit or pvc to protect it). Because of the longer runs, I was going to use 12awg, I know its a little over kill but might as well with the amount Im running.
I need to know if I should still use CL-2 rated?
And also my speaker wire lengths are all different. I've heard that you should use the same length for each set of speakers. Here are my lengths I need
50'6" Right Rear Speaker
41'4" Right Side Speaker
24' Right Front Speaker
18' Center Speaker
12' Left Front Speaker
11'4" Left Side Speaker
26'4" Left Rear Speaker
Should I just have the extra speaker wire for the shorter ones sit in the wall? or should I run the lengths I need? The biggest deal would be the two rears, almost a 25' difference is a lot of wire to just sit there.
Works out to about 195'6" exact and about 250' for exact lengths.
thanks
18' Center Speaker
thanks
Home Theater Setup
- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
Post edited by Theheadsn on
Just run the lengths you need, and yes, for in wall, you should use CL-2. At least if you want to be in code.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
good point, completely spaced on codeHome Theater Setup
- Sub - SVS PC-4000
Audio Quest 14/2 is a good wire and is CL2 rated. Not very expensive either. Do it right the first time.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Do you know off hand how much 200-250' would be? I dont mind spending money for good wires. But how about the distance to each speaker? 50' feet for expensive cable makes a differenceHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Sub - SVS PC-4000
