TSi500 Bi-amping
bassfreak
bassfreak Posts: 3
Does anyone know if there can be a significant increase in bass performance by bi-amping (not bi-wiring) the TSi500 speakers?
I have heard that some speakers benefit and some don't.
I wish to know because I can either have 5.1 bi-amped or regular 7.1
Gear:
Television: Toshiba tube, 27 inches, SD:eek:
HTiB: JVC TH-M505:eek:
VCR: Sony Hi-Fi Stereo
Playstation 3
Nintendo Wii
Radioshack Video Switcher:eek:
Post edited by bassfreak on
    EndersShadow Posts: 17,715
    edited March 2011
    long story short you will get the following answer here:
    Dont spend the time bi-amping from a receiver, and its a PITA to truly bi-amp since you need 2 amps (and one cannot be the receivers) and an external crossover as well.....
    Suggest getting a power amp if you can and read up lots....
    there are about 3 threads started in the last day or so on this subject......
  • bassfreak
    bassfreak Posts: 3
    edited March 2011
    Onkyo's newer receivers are set to bi-amp with only their built-in amps (and I think most others can do this now too)
    Thanks for the quick response.
    Gear:
    Playstation 3
    Nintendo Wii
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2011
    bassfreak wrote: »
    Yep but the more channles you run off the AVR the lower watts per channel it puts out. So it might be more benifical to hook them up regulary. I bi amped my RTI A7's on my onkyo 808 and couldnt really tell a difference. So I chose to not lower the out put by using 4 channels to drive the front 2 speakers. I left them hooked up regular.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 51,920
    edited March 2011
    bassfreak wrote: »
    That is not really bi-amping. Call it ghetto bi-amping at best. Goggle "how to bi-amp" and get your read on.
    edited March 2011
    I see my term is taking hold lol....
  • bassfreak
    bassfreak Posts: 3
    edited March 2011
    that is one of the best home theater terms I have ever heard.
    Thanks, everybody
    Gear:
    Playstation 3
    Nintendo Wii
