TSi500 Bi-amping
bassfreak
Does anyone know if there can be a significant increase in bass performance by bi-amping (not bi-wiring) the TSi500 speakers?
I have heard that some speakers benefit and some don't.
I wish to know because I can either have 5.1 bi-amped or regular 7.1
Gear:
Television: Toshiba tube, 27 inches, SD:eek:
HTiB: JVC TH-M505:eek:
VCR: Sony Hi-Fi Stereo
Playstation 3
Nintendo Wii
Radioshack Video Switcher:eek:
Playstation 3
Nintendo Wii
long story short you will get the following answer here:
Dont spend the time bi-amping from a receiver, and its a PITA to truly bi-amp since you need 2 amps (and one cannot be the receivers) and an external crossover as well.....
Suggest getting a power amp if you can and read up lots....
there are about 3 threads started in the last day or so on this subject......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »long story short you will get the following answer here:
Onkyo's newer receivers are set to bi-amp with only their built-in amps (and I think most others can do this now too)
Thanks for the quick response.Gear:
Playstation 3
Nintendo Wii
Radioshack Video Switcher:eek: -
Yep but the more channles you run off the AVR the lower watts per channel it puts out. So it might be more benifical to hook them up regulary. I bi amped my RTI A7's on my onkyo 808 and couldnt really tell a difference. So I chose to not lower the out put by using 4 channels to drive the front 2 speakers. I left them hooked up regular.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
That is not really bi-amping. Call it ghetto bi-amping at best. Goggle "how to bi-amp" and get your read on. -
I see my term is taking hold lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »I see my term is taking hold lol....
that is one of the best home theater terms I have ever heard.
Thanks, everybodyGear:
Playstation 3
Nintendo Wii
