Paint Scheme Help Needed
zingo
zingo Posts: 11,258
edited March 2011 in DIY, Mods & Tweaks
I will be building the chassis for my tube buffered class D amp this week, and will be building it out of MDF. I'm trying to figure out a decent paint scheme, and my first thought was black with the exterior sides an accent color. I know they make some cool metallic looking paint, or pearl, or brushed metal. It won't be the most high dollar chassis, but I'm wanting to do this on the cheap and I'm sure I can make it look decent. Ideas?
Post edited by zingo on
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2011
    Ferrari red brotha.
  • zingo
    zingo Posts: 11,258
    edited March 2011
    I do like Ferrari red...
    Does anyone have experience painting MDF? I've been reading up on it a little, and it seems a little tougher than regular pine boards.
  • [Deleted User]
    [Deleted User] Posts: 1,223
    edited March 2011
    Cover it with wood veneer and stain it. For high end you need a calssy look. Its not as hard as you may think and you'll love the results. :cool:
  • strider
    strider Posts: 2,568
    edited March 2011
    The raw edges of MDF need a bit of attention, you can't use anything that will introduce moisture to them. Moisture + MDF = swelling. First time out I used spackle to seal the edges, which in hindsight doesn't make much sense because it's (AFAIK) water based. Second time I used Bondo, which I felt was a PITA to work with. I think I didn't hit the right ratio of hardener to putty as it set up very quickly. Up side is it is extremely durable, unlike spackle. Since then I've been using an oil based primer and haven't looked back.
    For top coats, I've always been interested in trying out some of the techniques and products my wife uses in her faux finishing business. She's wood grained speakers and my rack for me already, I'd like to try some of the metallic finishes next. Modern Masters has some really neat stuff, especially the iron and copper bases with the top coats for various patinas.
    Wristwatch--->Crisco
  • Face
    Face Posts: 14,340
    edited March 2011
    Veneer, oil based primer, or how about red oak from Home Depot instead of MDF?
    nooshinjohn Posts: 26,064
    edited March 2011
    Get me some 100% accurate measurements and I can have it done in granite for you.
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    Granite would be sweet.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • bikerboy
    bikerboy Posts: 1,236
    edited March 2011
    Hi Jake,
    Wood veneer over the face that covers the ends of the side panels and paint on the rest wood! be cool. That way the end grain would be covered by veneer and no worries about the problems Strider talks about.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • zingo
    zingo Posts: 11,258
    edited March 2011
    It might turn out totally crappy, but I'm going to try semi-gloss black body with Ferrari Red front panel. I cut the wood yesterday, and will start painting tomorrow. I've got plenty of primer and 200 grit sandpaper, so hopefully it should turn out decent.
    Even if the amp doesn't look as good as I would hope/imaging, it will be one awesome sounding beast of 250wpc class D, Gold Lion 6922 buffered, integrated amp. :biggrin:
