What the heck causes....
kevhed72
paint to bubble when its drying? I am painting the HT room to be and keep getting these wet paint bubbles on the drywall...in spots that have been patched with drywall mud and then primed? When I scrape the bubble, I get both the paint layer and drywall layer peeled-off ???
:frown:
Post edited by kevhed72 on
Even after it's dried, the bubble is still there?
Did you use two different kinds of surface coating (1 oil based, 1 water based)?..... ><////(*> -
I scraped the larger bubbles before they completely dried. Both are water based. My guess is some type of of temperature difference between the wall and the cool air when I opened the windows to air the place out ???
my experience is has been moisture- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
usually moisture is the cause and even a slighly damp spot could cause a bubble...if the difference in temps caused some condensation.. but otherwise the temp shouldnt cause bubbles...at least I have never seen that....
Boy I don't know, I'd have to say "space herpes".
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
It is quite odd...due I ran the dehumidifier all last night before painting today.
Could it be the level of overall paint fumes in the air....all the bubbles I noticed were in a narrow stairway where I painted both sides of the walls. Hmmm
...unfortunately "SMOKE" or mosture can cause the problem. Wash with tsp
Not sure but I feel the wall may need to be sealed by primer first.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
If there has been alot of rain and moisture it could take a week to re-acclimate2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You always need to put a coat of primer over areas of drywall mud, tape, and spackle. If you don't have bubbles, you'll have cracks.
Sometimes using the wrong "nap" on your roller will cause that. Make sure you're using the right thickness rollers for the texture depth of the walls you're painting.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Exactly what i was going to say. Happened to me a couple times till i realized the error of my ways. -
Lets not get personal here ! :cool:
