What the heck causes....
kevhed72
kevhed72 Posts: 5,144
edited March 2011 in The Clubhouse
paint to bubble when its drying? I am painting the HT room to be and keep getting these wet paint bubbles on the drywall...in spots that have been patched with drywall mud and then primed? When I scrape the bubble, I get both the paint layer and drywall layer peeled-off ???:confused::frown::confused:
Post edited by kevhed72 on
  • fishbones
    fishbones Posts: 947
    edited March 2011
    Even after it's dried, the bubble is still there?
    Did you use two different kinds of surface coating (1 oil based, 1 water based)?
  • kevhed72
    edited March 2011
    I scraped the larger bubbles before they completely dried. Both are water based. My guess is some type of of temperature difference between the wall and the cool air when I opened the windows to air the place out ???
    VR3 Posts: 29,427
    edited March 2011
    my experience is has been moisture
  • NotaSuv
    NotaSuv Posts: 3,871
    edited March 2011
    usually moisture is the cause and even a slighly damp spot could cause a bubble...if the difference in temps caused some condensation.. but otherwise the temp shouldnt cause bubbles...at least I have never seen that....
  • gimpod
    gimpod Posts: 1,793
    edited March 2011
    Boy I don't know, I'd have to say "space herpes". :tongue:
  • kevhed72
    edited March 2011
    It is quite odd...due I ran the dehumidifier all last night before painting today.
    Could it be the level of overall paint fumes in the air....all the bubbles I noticed were in a narrow stairway where I painted both sides of the walls. Hmmm:confused:
  • dee1949
    dee1949 Posts: 1,425
    edited March 2011
    ...unfortunately "SMOKE" or mosture can cause the problem. Wash with tsp
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2011
    Not sure but I feel the wall may need to be sealed by primer first.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    txcoastal1 Posts: 13,513
    edited March 2011
    kevhed72 wrote: »
    If there has been alot of rain and moisture it could take a week to re-acclimate
    billbillw Posts: 7,541
    edited March 2011
    You always need to put a coat of primer over areas of drywall mud, tape, and spackle. If you don't have bubbles, you'll have cracks.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2011
    Sometimes using the wrong "nap" on your roller will cause that. Make sure you're using the right thickness rollers for the texture depth of the walls you're painting.
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2011
    steveinaz wrote: »
    Exactly what i was going to say. Happened to me a couple times till i realized the error of my ways.
  • [Deleted User]
    [Deleted User] Posts: 1,225
    edited March 2011
    steveinaz wrote: »
    Lets not get personal here ! :cool:
