Wattage,
thesurfer
thesurfer Posts: 574
edited March 2011 in Speakers
Why do companys make a reciever with 50, watts per channel, and another with 70??? both for stereo use, Does not the watts have to double, to make a differance? is this simply a selling point,
Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
Post edited by thesurfer on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    You have to double the watts to get a 3db difference. 1db is the smallest amount that a human can supposedly detect. The extra 20 watts would yield a small gain if the receivers are rated by the same standards.
    Ben
  • thesurfer
    edited March 2011
    Sooo, if Yamaha puts out a reciever that has 60, watts per channel, and a model up,,, that puts out 80, watts per channel, and cost a $100 more,,, your really getting ripped off,,, kinda what i figured,,,
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2011
    Not necessarily. Other elements come into play, such as does the 80 watter also have a beefier amp section, more current capability, etc.
  • thesurfer
    edited March 2011
    steveinaz wrote: »
    Butt, youd still have to double the watts, to notice it correct??
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2011
    there are more things to consider that just watts
  • aboroth00
    aboroth00 Posts: 1,106
    edited March 2011
    More watts = more spl. But there are more factors of how it gets there. Will it put out more current? Will it driver lower impedance loads? Does it have more dynamic headroom? Does it have a larger transformer?
    2Ch Tube Audio Convert
  • thesurfer
    edited March 2011
    aboroth00 wrote: »
    Got ya, all things need be considered,
  • lanchile
    lanchile Posts: 560
    edited March 2011
    a 200 watts per channel amp does not mean is better than a 50 watts amp. There are a lot of things to consider before you just say this amp is better because it has more power. To me it is not just quantity, but Quality.
    I have a Bryston B60-R integrated amp that is just 60 watts per channel. I have compared it side by side with way more powerful amps and integrated amps, but the Bryston B60-R with just "60 watts" put the other more powerful amps on shame. The same goes to speakers!!!:wink:
    Make it simple...Make it better!
    mhardy6647 Posts: 34,934
    edited March 2011
    3.5 watts per channel on my real hifi in the living room (and vintage output tubes that are older than I - and that's old).
  • PolkClyde
    PolkClyde Posts: 662
    edited March 2011
    The Rule I follow is, the more watts,the better. you can do more harm to your amp and speakers with a lower watt amp. Let's talk Distortion,Clipping.
    PolkAudioClyde
    edited March 2011
    PolkClyde wrote: »
    Very true for a solid state amp; much less likely with vacuum tube amps.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited March 2011
    thesurfer wrote: »
    That is sure a factor (Marketting has its purpose and can use many form)
    thesurfer wrote: »
    Not exactly, what other features are offered from the more expensive receiver? Any of them of any value to you? Are yo talking receiver or audio video receiver (AVR). Just a few extra options that are of use to YOU may justify the extra cost.
    As steveinaz points out, other factors are to be considered ("beefier amp section, geared toward "more current capability"). NOT all watts are equal, watts are the combination of the voltage and current (ExI). An amp, receiver, AVR that focus on providing you with larger current will perform much better than less current with more voltage and of course such circuitry is more expensive.
    thesurfer wrote: »
    You are right but do not focus too much on the GREATHER POWER the BETTER as this is far from being always true. Less but of good quality is better than more but on the cheap.
    lanchile wrote: »
    ...To me it is not just quantity, but Quality.
    Exactly, you must focus on QUALITY rather than QUANTITY.
    PolkClyde wrote: »
    Your statement is somewhat correct but can not be considered as absolute truth. More CRAPPY watts simply means more distortion, clipping and therefore more harm to the speakers. Do you realize most people in normal circomstances will not drive their system that much more than 10 watts?
    One should focus on quality watts, keep the amp/Rx/AVR fairly close to the speaker rating and make sure the amp/Rx/AVR has enough headroom so neither the amp/Rx/AVR and speakers struggle when used at decent or even louder level. Choose the above gear considering the room you are trying to fill and your personal loudness taste. By doing so, the only thing you have to worry about being damaged if you abuse is your hearing ;) I never blew any of my gear and it is just average and I have to admit my prefered listening levels are often way more than 10 watts ;)
    BTW, nice "T:smile::smile:Bs" MH :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • lanchile
    lanchile Posts: 560
    edited March 2011
    TECHNOKID wrote: »
    Very well said! I have build many amps even some from NELSON PASS. one of them was only 10 watts. But the key here is as you said is in QUALITY WATTS!!!
    I would rather have a well design 50 watts amp than a crappy and fatiguing 200 watts amp that will make my ears bleed.
  • McLoki
    McLoki Posts: 5,231
    edited March 2011
    Then again, sometimes, there is nothing wrong with a great big amp....
  • Cayuga
    Cayuga Posts: 480
    edited March 2011
    Size does matter but not with an amp
  • McLoki
    McLoki Posts: 5,231
    edited March 2011
    Cayuga wrote: »
    I would argue that size is a factor, just not the only factor.
    A smaller better sounding amp is a usually a better choice than a larger poor sounding one, but a large, great sounding amp would be my choice over a small great sounding one.
    Movies have a 20db dynamic range as an average. Not the best choice for a small amp. Of course if you are using it mainly for listening to rock music (typically a lower dynamic range) in a small room with efficient speakers, you can get by with only a few watts.
    Basically an amp needs to be matched to your needs and with the rest of your system taken into account. The perfect fit for my system may not be the perfect fit for yours....
    Michael
