Suggested cables
ddkalfa
ddkalfa Posts: 20
edited February 2011 in Speakers
Hi, I'm assembling my system now, and would like to know what cables should I buy?
I've heard good recommendations on Blue Jeans Cables, does anybody know them?
Polk Monitor 70s
Polk Monitor 30s
Polk CS2
Polk PSW505
Onkyo RC270
  • ken brydson
    ken brydson Posts: 9,103
    Blue Jeans are good, So are Signal, MIT, etc. What's your budget?
  • ddkalfa
    ddkalfa Posts: 20
    I'd say around $100 for everything, including banana plugs ... Is that possible?
  • dragon1952
    dragon1952 Posts: 4,942
    Although I love their LC-1 interconnects, I didn't like either speaker wire in several different systems. Plus the Belden is pretty stiff and heavy and the Canare is pretty thick. Is the listed system the one you are buying for? And how long are the runs?
  • ddkalfa
    ddkalfa Posts: 20
    Yes, that's the system I'm buying for.
    Around 3 meters for front items (front pair, central and sub), and around 13 meters for surrounds.
  • dragon1952
    I should have asked how you were wanting to run the cable to the rears. Is the cable going to be visible or are you wanting to stuff it under baseboards?
  • ddkalfa
    ddkalfa Posts: 20
    dragon1952 wrote: »
    I plan to stuff them under baseboards ...
  • Upstatemax
    Upstatemax Posts: 2,865
    I use speaker wire from Monoprice, CL2 rated 12ga with GLS locking Banana plugs for all receiver connections and GLS spade connections for the speakers.
    Been very happy with that set up for my main HT system and my 2ch...
  • dragon1952
    Upstatemax wrote: »
    In your price range I think I'd agree, at least for the rears. The white jacket is nicer looking than the clear PVC, IMO. And that would be easy to stuff under the baseboards. You could use the same all around if you want or look for something a little dressier for the fronts. Like the Signal Cable Classic for around $90 a pair in your length, and maybe a single for the center. That would push your total up to around $150 maybe. For the sub just get a length of coax with RCA's like this,
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=6305&seq=1&format=2
    Here's a link for the Signal Cable http://signalcable.com/classicspeaker.html
  • fattmann
    fattmann Posts: 58
    dragon1952 wrote: »
    I generally don't comment on topics of cables/interconnects and the like due to lack of interest/knowledge- but just felt compelled to note how silly some of this cable talk is.
    Suggesting $90pr wire for the fronts, then skimping out for a $3.50 cable for the sub? That just doesn't make sense to me. If you are going to get nice cables, do it all around, or save yourself the cash. Point of nice cables is to give an unbalanced-true sound, defeats the purpose if you are using "nonfancy" cables for certain channels.
    Unless you wanted it to look nicer for the fronts as dragon mentioned, then by all means, looks do play a role in a good system.
    I apologize, just felt like throwing my copper coins in.
    Components in The Rack:
    Yamaha RX-V765 7.1 AVR
    Sony TA-N511 (from 1065 to sub)
    Xbox One
    MA PD-915R Power Strip
    Monster HTS-1650
    Speakers:
    L/R- Polk TSI-500 Cherry, 12awg in place of jumpers
    C- Polk CS20 Cherry
    SRs- Polk TSI-100 Cherry
    Sub- Kicker S12L5, vented box
    Display:
    Sony VPH-1252Q
    75" 16:9 DIY BO Cloth Screen
    Not running:
    Crown Straight Line Two
    Crown Power Line Four
    Pioneer PD-F908
    Fender BXR Dual Bass 400
    Pioneer BDP-51
  • B Run
    B Run Posts: 1,888
    There's a big difference is analog cables vs digital cables. Sub cables don't matter as much as long as they deliver the digital signal without interference. Analog cables are a whole different beast and do matter a lot more. I'm using the signal cable analog II interconnects ($145) and a $10 sub cable.
  • fattmann
    fattmann Posts: 58
    B Run wrote: »
    I don't think the sub-out is digital. I guess it could be if you have a dedicated LFE out.. I have my sub out going into a very analog 400w guitar amp with an RCA->1/4" and it works just fine.
    Xbox One
    Monster HTS-1650
    Speakers:
    C- Polk CS20 Cherry
    Display:
    Sony VPH-1252Q
    Not running:
    Pioneer PD-F908
    Pioneer BDP-51
  • dragon1952
    All the sub needs is a very basic coax. That's not skimping by any means. It is a low frequency, low bandwidth signal. It does not require anything other than RG6.
  • ben62670
    ben62670 Posts: 15,969
    Canare S411 speaker wire in bulk. It only cost $1.29 per foot. Also you could use something even cheaper for the rears like the monoprice.
    Ben
  • fattmann
    fattmann Posts: 58
    My point is it's silly to suggest good wire for one set, and not another. That'd be like putting street tires on the rear, and racing tires on the from of a race car- everything effects the performance.
    Xbox One
    Monster HTS-1650
    Speakers:
    C- Polk CS20 Cherry
    Display:
    Sony VPH-1252Q
    Not running:
    Pioneer PD-F908
    Pioneer BDP-51
  • ben62670
    If the front 3 are matched you are good. The rears are much longer runs and I have used decent cheap 14ga wire for surrounds. The rears are not nearly as critical as the fronts. For a drag car you would put the coin into rear tires. For sports driving you would match the tires. Also I have no idea why I am talking about cars? The car analogy has nothing to do with sound.
    Ben
  • dragon1952
    Also, no one is suggesting any 'bad' wire. All I did was suggest 'dressier' wire for the fronts where you have to look at it. As for the sub, what do you suggest that is better than RG6?
  • ben62670
    The sub cable is not digital. It is analog. The frequencies required by the sub is in the very lower end of the spectrum. Usually where you will notice the biggest gains using a nice IC is the upper ranges and sound stage... The RG6 should be fine. If others have tried RG6 and something like signal, or Blue Jeans I would be all ears to hear what they have to say about the differences. This sytem is a nice step up from a typical HTIB, but it is not high end stereo reproduction.
    Ben
  • dragon1952
    BTW, I was replying to fattmann. I should have done a quote and reply.
  • ScudDawg
    ScudDawg Posts: 68
    ben62670 wrote: »
    completely agree about the front 3 and surrounds
    Home Theater:
    Processor: Emotiva UMC-1
    Amps: Emotiva XPA-3, Emotiva UPA-5
    Center: Polk Audio CSi A6
    Fronts: Polk Audio RTi A7
    Surrounds: Polk Audio FXI A4
    Surround Rears: Polk Audio RTI A3
    Subwoofer: SVS 2039 PCi (upgraded woofer)
    Power Conditioner: Monster HTS 5100 Signature Series
    2 Channel: (work in progress)
    Speakers: Polk Audio Monitor 40
  • photocrazy
    photocrazy Posts: 89
    B Run wrote: »
    So for analog signals, do the brand of interconnects matter ? Even for speaker wires?
  • ben62670
    It's not the brand so much as the model. Chevy made the Chevette and the Corvette. Both are Vette's, but there is a huge difference.
    Ben
  • dragon1952
    photocrazy wrote: »
    I would say the materials used and the electrical properties are the most important aspects. Materials, as in the purity of the metals (conductor and shielding) and quality of the connectors, and electrical properties, as in resistance, capacitance, and/or inductance. For audio IC's you want low capacitance and low shield resistance. For speaker wire you want low resistance. Some cables tweak the sound by increasing capacitance or resistance which could have the effect of rolling off the highs, which in turn could cause the particular cable to sound different than another.
    Fancy cable geometries and dielectrics are other factors that can be claimed to improve sound, and possibly increase price.
    This is pretty good instructional reading,
    http://www.bluejeanscable.com/store/audio/LC1-design-notes.htm
    I've tried a ton of IC's over the years and those LC-1's are as good or better than any I've tried and are currently what I am using.
    As for speaker wire I prefer pure copper and heavy gauge conductors with relatively low strand count. You don't have to go expensive for those qualities.
