Emotiva amplifiers and my Tsi setup
KyleM
hey guys just wondering what everyone here thinks about this.
now i'm looking at investing in a nice amplifier.
emotiva's amplifiers are in my price range, specifically the UPA-7 and the XPA-3.
now what do you think would be better, buying the UPA 7 which is a 7 channel amplifier with 125 wpc and run my fronts bi-amped and also have my rears amplified.
OR
get the XPA 3 which is a 3 channel rated at 200 wpc running my centre and fronts?
my main use for all of this is home theatre, but i do like music through the multi channel. any help would be greatly appreciated! :biggrin:
OR
HT: Onkyo HT-RC270, Polk Audio Tsi 500, Polk Audio Tsi 300, Polk Audio CS20, Velodyne VDR12, Polk Audio PSW111
Room: Sophia electric baby(tube), GF Dac-11, Totem Mite's
Post edited by KyleM on
i guess it would be nice to add a signatureHT: Onkyo HT-RC270, Polk Audio Tsi 500, Polk Audio Tsi 300, Polk Audio CS20, Velodyne VDR12, Polk Audio PSW111
Room: Sophia electric baby(tube), GF Dac-11, Totem Mite's -
Personally i'd go XPA-3 because your receiver shouldn't have any problem driving a pair of Tsi300's. That's just one vote though, i'm curious to see what the general consensus is.
Out of the two amps I would agree with above. -
hmm such a tough decision.
what is the power distribution in the Tsi 500's?
i heard that when regular amped they run the tweeter and three of the 6.5" drivers leaving the 4th as passive.
but when bi-amped it dedicates top tweeter and 2 drivers to highs/mids and the lower 2 to a lower mid.
can anyone verify this?HT: Onkyo HT-RC270, Polk Audio Tsi 500, Polk Audio Tsi 300, Polk Audio CS20, Velodyne VDR12, Polk Audio PSW111
That's not correct at all. The work exactly the same way, all you would be doing is taking off the metal jumpers and powering both sets of binding posts separately. You're better off with more watts per channel and quality jumpers, but there's hundreds of threads here arguing that, i'll let you decide for yourself. -
Actually, the OP is better off with a high current amp, than more watts per channel.
http://www.youtube.com/watch?v=Y_22XOakyxMpolk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
XPA-3 gets my vote....Fronts: Polk RTi A7's
Center: Polk CSi A6
Surrounds: Polk TSi500's
Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
Amplifier: Emotiva XPA-5
Processor/AVR: Emotiva UMC-1
DAC: Emotiva XDA-1
CD player:Emotiva ERC-1
Blu-Ray: Oppo BDP-93
Turntable: Kenwood KD-500
Tonearm: Polk-Mayware Formula 4
Cartridge: Shure M97-XE
Television: Sony KDL-55EX500 -
+1 .. But you still need a Pre-amp.. To run any of these power amps in question. Do you already have one?Onkyo NR-3007
Carver M-4.0t
Parasound HCA 1200MKII
Parasound HCA 2205A
RTI-A9
Csi-A6
Tsi-100 (Highs)
M5 (Rear)
Rti6(Surrounds)
RT7(Wides)
Oppo DV-981HD
PS3
X360
Klipsch Sub12
Klipsch Sub10 -
+1, without an amp with Pre-outs for the amp, it isn't going to do you any good. If memory serves me the RC Onkyo models are from HTIB type setups, and most of those don't have the needed pre-outs for adding an external amp.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Lets not forget that your speakers are very easy to drive, and you have a sub in the mix to handle the low end. Bi-amping would be wasted. Knock your socks off if thats what you want to do though,it's your coin.HT SYSTEM-
lsi 9's -
thanks for the advice everyone. i think i will probably go with the xpa-3, and run the rears with the amp like you guys said.
also the HTRC270 is actually not a HTIB, it is basically the same model as the TX-NR708. so it does have pre-outs the only big difference is the NR708 has 110 WPC 2 channels driven whereas mine has 100WPC.
last question though,
do you guys think addition of this amp will make a noticeable difference?HT: Onkyo HT-RC270, Polk Audio Tsi 500, Polk Audio Tsi 300, Polk Audio CS20, Velodyne VDR12, Polk Audio PSW111
Amp section is the same on them both - they're just rated differently.
708 has 1 more HDMI, RS-232, and a 12V trigger.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Any speaker will benefit from a good power source. The degree of that benefit has many variables, and only you can be that judge.HT SYSTEM-
lsi 9's -
Yeah buddy, you will hear a difference! My Xpa5 really woke up my system. Go for it and dont look back!LIVING ROOM:Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power ConditioningBEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection. -
spock 2054 wrote: »Actually, the OP is better off with a high current amp, than more watts per channel.
Don't think he needs more current driving 8 ohm speakers. If there is a significant dip, maybe, but otherwies he's probably fine2Ch Tube Audio Convert -
Just because it's rated at nominal 8 ohms doesn't mean you don't or can't benefit from more current. Current is King and watts is just the standard everyone's accepted as a measuring tool (wrongly I might add).
angelsfann02 wrote: »Yeah buddy, you will hear a difference! My Xpa5 really woke up my system. Go for it and dont look back!
+1 Just got my new XPA-5 hooked up and even with my M70s it is night and day from avr to avr/amp.
Onkyo 808
Emotiva XPA-5
Polk Audio M70s fronts
Polk Audio Cs1 center
Polk Audio 50s surrounds
Polk Audio 30s backs
Polk Audio Psw505 sub
Polk Audio Psw10 sub
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
HTPC Evga P55/Intel i7-860/Evga 260 Sli -
At 8ohm nominal, at most the speaker probably dips to 6ohms maybe even occasionally which I doubt to 4ohms. Of course we cannot really know unless we see an impedance curve.
At 8ohms, running normal levels wattage needed is relatively low meaning current needed is relatively low. When the impedance dips as typically lower frequencies and at higher volumes, more current is needed to push the speaker. However there are many other things to be measured in an amplifier such as dynamic headroom. As for a high current amp being stable into lower impedances (more current), it's not quite needed with 8 ohm nominal speakers.
These speakers were most likely designed by polk to be run by a receiver, and at this load, it can be handily done. As for marked improvements from an amp, only experimentation can yield results. As for just pinning it on the need of a high current amp that's not entirely true, there are just many more factors.2Ch Tube Audio Convert -
My bad, they used the HT in older models of their HTIB AVR's. Guess I should have Google'd it before I opened my big mouth, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Can you swing an extra 200 bucks? The XPA-5 is a brute and will really take care of all your speakers.
If you wait till the next sale, the xpa-5 will cost the same as the xpa-3 anywayI'm the Dude. So that's what you call me. You know, that or, uh, His Dudeness, or uh, Duder, or El Duderino if you're not into the whole brevity thing. -
Thanks everyone for the help, its been greatly appreciated.el_duderino wrote: »Can you swing an extra 200 bucks? The XPA-5 is a brute and will really take care of all your speakers.
now i was thinking of doing that, but my worry is that because its rated at 200WPC and my rear speakers are only 150watts, will that increase the probability of blowing them?
i do tend to play music very loud.
another question i have though is that because my receiver does not have a 12v trigger out, how would i run an amplifier. i understand i can manually turn it on and off every time.
i saw two solutions one involving a smart power bar, and one involving making an external trigger. anyone have another solution?HT: Onkyo HT-RC270, Polk Audio Tsi 500, Polk Audio Tsi 300, Polk Audio CS20, Velodyne VDR12, Polk Audio PSW111
All of your speakers will be just fine. They will only take as much power that they need to operate to their full potential. Your ears will give out before the speakers do if you get too carried away with the volume. As for your amp, just leave it on all the time, or if it has an auto on feature, put it on that & it will wake up when it receives a signal from your speakers.Thanks everyone for the help, its been greatly appreciated.
i saw two solutions one involving a smart power bar, and one involving making an external trigger. anyone have another solution?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I really wanted to go with the upa7. I had planned to bi amp the fronts and run the rest also, but space wouldn't let me.
Either way you are going to be happy with the upgrade and added power. A separate amp will really wake up your speakers.Receiver: ONKYO 709
Amplifier: Acurus A200x3
Front: EmpTek E55Ti
Center: EmpTek E56Ci
Surround: EmpTek E5Bi
Sub: Elemental Designs A5-350
TV: LG 55"
Blu-Ray: PS3 -
Ive heard you cant bi amp the front speakers off the same external amp? wouldnt you need to different amps along with a crossover? Correct me if Im wrongHome Theater Setup
- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
I don't know why you would need an external crossover or separate amps.Receiver: ONKYO 709
Front: EmpTek E55Ti
TV: LG 55"
Blu-Ray: PS3 -
It's not bi-amping then. Is a triathalon a single event run 3 times or 3 events run a single time?
Using the same amp, sharing a power supply and passive x-over is not true bi-amping.
http://en.wikipedia.org/wiki/Bi-amping
Short and sweet ^
So far this is my favorite quote this week lol....
not that I can say much since I am "ghetto bi-amping" lol....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
haha exactly atleast im sorta learning something here.
So far ive realized that "REAL" bi amping is A) hard to accomplish, and
very expensive.
If you can do it, hell that would be sweet, but honestly has anyone done bi amping the correct way that could give their opinions on how the sound difference was?
Not normal bi amping from one receiver but from actually seperate amps and crossoversHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Sub - SVS PC-4000
I believe ben62670 ran active for a bit, shoot him a PM and see..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
TSi's????? Get the UPA-7!!!!
