PSW505 Setup
jhood2880
jhood2880 Posts: 54
edited February 2011 in Speakers
Can anyone explain to me why and what are the differences between LFE and Line in on the PSW505. It will be delivered today and i want to know what the differences and benefits are. Thanks
Living Room
TV - Sony 60" LED KDL-60EX700
Receiver#1 - Sony STR-DN2010
Receiver#2 - Pioneer VSX
Front: Monitor 70II's
Center: CS2II
Rear: Monitor 40II's
Sub: PSW505
Master Bedroom
TV - Sony 55"
  • jbooker82
    jbooker82 Posts: 1,627
    I belive LFE uses only 1 channel (mono sub out put from the avr) and line in would use 2 rca Left and Right cables. Also when you use LFE the low pass filter is bypassed and you use or let the AVR set the Hz.
    You want the LFE to be set at 120hz in the avr. In a 5.1 home theater setup the .1 is the sub (LFE track). When the sound effects are recorded there are certian sounds that are dedicated to the LFE sound track. The LFE has sounds that are up to 125 hz. So if you set it lower then you wont hear them because the low pass filter will block it. Since it is recorded as the .1 LFE track your other speakers will not reproduce the sound since it was dedicated to the LFE track when it was recorded.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • nguyendot
    nguyendot Posts: 3,594
    LFE is unfiltered, should bypass the crossover completely because your receiver will be doing the crossover for you.
    Main Surround -
  • jhood2880
    jhood2880 Posts: 54
    Awesome thank you both!
    Living Room
    Center: CS2II
    Sub: PSW505
    Master Bedroom
    TV - Sony 55"
