PSW505 Setup
Can anyone explain to me why and what are the differences between LFE and Line in on the PSW505. It will be delivered today and i want to know what the differences and benefits are. Thanks
Living Room
TV - Sony 60" LED KDL-60EX700
Receiver#1 - Sony STR-DN2010
Receiver#2 - Pioneer VSX
Front: Monitor 70II's
Center: CS2II
Rear: Monitor 40II's
Sub: PSW505
Master Bedroom
TV - Sony 55"
Center: CS2II
Sub: PSW505
Master Bedroom
TV - Sony 55"
I belive LFE uses only 1 channel (mono sub out put from the avr) and line in would use 2 rca Left and Right cables. Also when you use LFE the low pass filter is bypassed and you use or let the AVR set the Hz.
You want the LFE to be set at 120hz in the avr. In a 5.1 home theater setup the .1 is the sub (LFE track). When the sound effects are recorded there are certian sounds that are dedicated to the LFE sound track. The LFE has sounds that are up to 125 hz. So if you set it lower then you wont hear them because the low pass filter will block it. Since it is recorded as the .1 LFE track your other speakers will not reproduce the sound since it was dedicated to the LFE track when it was recorded.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
LFE is unfiltered, should bypass the crossover completely because your receiver will be doing the crossover for you.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Awesome thank you both!Living Room
Center: CS2II
Sub: PSW505
Master Bedroom
TV - Sony 55"
