iTunes 24bit
skrol
skrol Posts: 3,465
edited February 2011 in Music & Movies
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • PrazVT
    PrazVT Posts: 1,607
    That would be sweet.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • [Deleted User]
    [Deleted User] Posts: 1,223
    Good article, thanks for the post. :cool:
  • mantis
    mantis Posts: 17,563
    Sacd and dvd audio failed. Hi res music doesn't appeal to the general market. But that doesn't mean they can't release the 24 bit version of what has been recorded.
    Digital music should replace the cd in all forms. From what I have learned , a heard drive can outperform any cd transport. You can store instead of hand changing your music.
    I believe anywhere you buy your music it should be a copy of the original. Then if you are going to replay that file on a lower res system , it just down grades it, not from the start.
    Why must we live in a world where down graded anything is except able?
    Dan
  • nguyendot
    nguyendot Posts: 3,594
    mantis wrote: »
    But then you have to buy $1000 sata cables, and $2000 sata power wires to get best performance :)
    Main Surround -
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    nguyendot wrote: »
    Those are only necessary if you are using fans to cool your PC's internal components, as fans are notorious contributors of electrical and mechanical noise to the signal path. A far superior solution is to eliminate the fans by submerging your PC in Crisco, at least until MIT gets around to making SATA interconnects.
  • PrazVT
    PrazVT Posts: 1,607
    lol. or you can go liquid cooling. If you're not overclocking, you can pretty much shut off all the fans (case, radiator). About the only thing that would need to run is the water pump. hell even overclocked, if I'm not encoding blu-ray -> x264, I pretty much shut down everything except the giant window fan.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • On3s&Z3r0s
    PrazVT wrote: »
    That's no good, the pump's still got a motor. Crisco FTW!!! :wink:
  • Ace944gs
    Ace944gs Posts: 110
    Not sure if this is posted elsewhere, but all this talk about 24bit recordings on iTunes made me look into the latest on their N.C. data center...funny enough, they're rumored to go live sometime this spring.
    My hope? 24 bit download options for the good stuff/keeper music, and a subscription based model for the background stuff! (all at a reasonable cost, of course... otherwise I'm sticking with CDs/LPs).
    http://www.appleinsider.com/articles/11/02/23/apple_says_nc_data_center_will_support_itunes_and_mobileme_this_spring.html
    As much as I'm tired of Apple's greater-then-thou attitude on pretty much everything, I get excited about these things. We all benefited from them bullying the recording industry in the early part of the last decade...hope they can keep it up.
  • PrazVT
    PrazVT Posts: 1,607
    Upgrades would be messy though :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • On3s&Z3r0s
    PrazVT wrote: »
    But so nice to have your PC smell like french fries all the time! :tongue:
    Ok, enough LuLz... sorry for diverting the thread.
