interconnects
K-daugh
K-daugh Posts: 467
do interconnects between receiver and five channel amp have to be "digital coaxial" or "analog"
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
  • fishbones
    fishbones Posts: 947
    edited February 2011
    analog
  • angelsfann02
    angelsfann02 Posts: 589
    Are you looking to buy some at Monoprice? I had the same confusion when looking at theirs too.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • K-daugh
    K-daugh Posts: 467
    yes i am looking at monoprice if im hooking up a five channel amp to my receiver can i use the high quality coaxial :3ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable M/M RG6U 75ohm Gold connector (for S/PDIF, Digital Coax, Subwoofer & Composite Video) or should i use the analog:3ft Premium 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - Black
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    i would rather the high quality coaxial
    Custom Jumpers
  • steveinaz
    steveinaz Posts: 19,545
    Blue Jeans uses Belden coaxial on their analog interconnects. Very good stuff, on the cheap.
  • K-daugh
    K-daugh Posts: 467
    im sticking with monoprice its all i can afford at the moment was wondering which monoprice cable to get?
    Custom Jumpers
  • steveinaz
    Get the best cable you can afford. I use some monoprice "premium" RCA's on my vintage 70's rig.
  • K-daugh
    K-daugh Posts: 467
    yeah thats what i am leaning towards they would work for interconnects right?
    Custom Jumpers
  • steveinaz
    Yep, if you're lookig at their "premium" RCA's...they seem fairly well made and relatively respectable performance.
  • K-daugh
    K-daugh Posts: 467
    thank you
    Custom Jumpers
  • steveinaz
    These are the type I have in the 70's mancave:
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2869&seq=1&format=2
    Nothing to write home about, but they get the job done.
  • rooftop59
    rooftop59 Posts: 8,120
    I use the monoprice premium interconnects for the multi-channel analog outputs on my bp and they work fine. I don't have high end stuff to compare them to, but them seem awfully close to my dayton reference interconnects. I say go for it.
    Game Room 5.1.4:
    Bedroom 2.1
  • K-daugh
    K-daugh Posts: 467
    oh see thats where im alittle confused do i get those or do i get the digital ones
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    monoprice said the digital ones will work just fine
    Custom Jumpers
  • rooftop59
    Game Room 5.1.4:
    Bedroom 2.1
  • K-daugh
    K-daugh Posts: 467
    ok so just get three pairs for a five channel amp
    Custom Jumpers
  • rooftop59
    yep. done.
    Game Room 5.1.4:
    Bedroom 2.1
  • steveinaz
    K-daugh wrote: »
    Yep, digital is fine too--they are probably the exact same cable.
  • K-daugh
    K-daugh Posts: 467
    thanks guys im gonna go with 5- 3ft digital ones monoprice says they are a better quality cable than the 2 rca style and they support digital and analog
    Custom Jumpers
  • steveinaz
    Must be the RG-6 based one right?
  • K-daugh
    K-daugh Posts: 467
    yes sir
    Custom Jumpers
  • steveinaz
    That should work nicely--it's got a larger center conductor.
  • rooftop59
    sweet cables...learn somin new everday here on cp!
    Game Room 5.1.4:
    Bedroom 2.1
  • bamark
    bamark Posts: 32
    +1 on the Premium Monoprice cables. They look good, work great, and did not cost a lot. I changed out all my RCA cables to these (1.5 and 3ft), and am quite satisfied
    Office:
    Pioneer SX-650
    Pioneer RG-1
    BSR EQ-110X
    Technics SL-23
    Polk Monitor 5's
    Samsung DVD M101 (transport)
    Entech Number Cruncher 203.2
    Living Room:
    Pioneer SX-850
    Pioneer SG-9500
    Pioneer HPM-60's
    JVC XL-V161 CD Player
  • steveinaz
    They are pretty well made given their extremely low price. A no-brainer even for the non-enthusiast to replace the cheapy's they throw in the box with components.
  • K-daugh
    K-daugh Posts: 467
    right right.....they may not be equivalent to mit or cardas or even signal cable but if your ears have never heard these high end cables then the monoprice are more than acceptable.....also if your pockets dont allow the 400 dollar interconnect then monoprice is even more relevant....and no im not trying to start a cable war im just stating my somewhat educated opinion....and yes i am on the monoprice bandwagon....at the moment!!!!
    Custom Jumpers
  • steveinaz
    It's not that a particular cable is better or worse than another; but more about the changes in tonal character, and/or lack of grain that different cable materials/topolgies can provide.
  • K-daugh
    K-daugh Posts: 467
    steveinaz wrote: »
    your absolutely right but if my ear already likes the tonal character of a monoprice cable then why change....If for some reason i feel like something is missing but i cant quite put my finger on it then yes maybe it would be time to upgrade.... IMO where monoprice cables are so cheap...this should be a starting point for everybody ....if they dont like them they can upgrade and there only out say maybe $100.00 for an entire system.... that is a bargain....but its better then dropping say five hundred on cables and still not being satisfied...again this is only my opinion ..which means nothing to my wife and kids generally....so why would it be taken seriously hear lol:biggrin:
    Custom Jumpers
  • John K.
    John K. Posts: 822
    K-d , although the pre-outs of course send analog signals to the amplifier for amplifying by adding more voltage, it doesn't matter if the coaxial cable carrying them down the outside of its conductor is labeled "analog" or "digital" by the seller. These cables can differ in their characteristic impedance from around 40 ohms to the 75 ohms specified for digital connections, but the difference has no significance for your use.
    Yes, sellers such as MonoPrice and the Tartan Cable division of Blue Jeans have demonstrated to savvy buyers that there's no correlation between price and sound quality in this area. You seem to have a good grasp of this reality now, but don't buy into the mythologies that the peddlers of high-priced pieces of magic wire try to keep alive despite the lack of solid evidence to support them.
  • ben62670
    ben62670 Posts: 15,969
    Again John has no evidence that we can't hear what we hear:rolleyes:
    Ben
