interconnects
K-daugh
do interconnects between receiver and five channel amp have to be "digital coaxial" or "analog"
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Are you looking to buy some at Monoprice? I had the same confusion when looking at theirs too.LIVING ROOM:Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power ConditioningBEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection. -
yes i am looking at monoprice if im hooking up a five channel amp to my receiver can i use the high quality coaxial :3ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable M/M RG6U 75ohm Gold connector (for S/PDIF, Digital Coax, Subwoofer & Composite Video) or should i use the analog:3ft Premium 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - BlackBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
i would rather the high quality coaxialBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Blue Jeans uses Belden coaxial on their analog interconnects. Very good stuff, on the cheap.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
im sticking with monoprice its all i can afford at the moment was wondering which monoprice cable to get?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Get the best cable you can afford. I use some monoprice "premium" RCA's on my vintage 70's rig.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
yeah thats what i am leaning towards they would work for interconnects right?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Yep, if you're lookig at their "premium" RCA's...they seem fairly well made and relatively respectable performance.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
thank youBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
These are the type I have in the 70's mancave:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2869&seq=1&format=2
Nothing to write home about, but they get the job done.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I use the monoprice premium interconnects for the multi-channel analog outputs on my bp and they work fine. I don't have high end stuff to compare them to, but them seem awfully close to my dayton reference interconnects. I say go for it.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
oh see thats where im alittle confused do i get those or do i get the digital onesBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
monoprice said the digital ones will work just fineBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
this is what you want, but of course the length will vary:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=5346&seq=1&format=2Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
ok so just get three pairs for a five channel ampBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
yep. done.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Yep, digital is fine too--they are probably the exact same cable.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
thanks guys im gonna go with 5- 3ft digital ones monoprice says they are a better quality cable than the 2 rca style and they support digital and analogBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Must be the RG-6 based one right?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
yes sirBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
That should work nicely--it's got a larger center conductor.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
sweet cables...learn somin new everday here on cp!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
+1 on the Premium Monoprice cables. They look good, work great, and did not cost a lot. I changed out all my RCA cables to these (1.5 and 3ft), and am quite satisfiedOffice:
Pioneer SX-650
Pioneer RG-1
BSR EQ-110X
Technics SL-23
Polk Monitor 5's
Samsung DVD M101 (transport)
Entech Number Cruncher 203.2
Living Room:
Pioneer SX-850
Pioneer SG-9500
Pioneer HPM-60's
JVC XL-V161 CD Player -
They are pretty well made given their extremely low price. A no-brainer even for the non-enthusiast to replace the cheapy's they throw in the box with components.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
right right.....they may not be equivalent to mit or cardas or even signal cable but if your ears have never heard these high end cables then the monoprice are more than acceptable.....also if your pockets dont allow the 400 dollar interconnect then monoprice is even more relevant....and no im not trying to start a cable war im just stating my somewhat educated opinion....and yes i am on the monoprice bandwagon....at the moment!!!!Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
It's not that a particular cable is better or worse than another; but more about the changes in tonal character, and/or lack of grain that different cable materials/topolgies can provide.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
your absolutely right but if my ear already likes the tonal character of a monoprice cable then why change....If for some reason i feel like something is missing but i cant quite put my finger on it then yes maybe it would be time to upgrade.... IMO where monoprice cables are so cheap...this should be a starting point for everybody ....if they dont like them they can upgrade and there only out say maybe $100.00 for an entire system.... that is a bargain....but its better then dropping say five hundred on cables and still not being satisfied...again this is only my opinion ..which means nothing to my wife and kids generally....so why would it be taken seriously hear lol:biggrin:Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
K-d , although the pre-outs of course send analog signals to the amplifier for amplifying by adding more voltage, it doesn't matter if the coaxial cable carrying them down the outside of its conductor is labeled "analog" or "digital" by the seller. These cables can differ in their characteristic impedance from around 40 ohms to the 75 ohms specified for digital connections, but the difference has no significance for your use.
Yes, sellers such as MonoPrice and the Tartan Cable division of Blue Jeans have demonstrated to savvy buyers that there's no correlation between price and sound quality in this area. You seem to have a good grasp of this reality now, but don't buy into the mythologies that the peddlers of high-priced pieces of magic wire try to keep alive despite the lack of solid evidence to support them. -
Again John has no evidence that we can't hear what we hear:rolleyes:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
