New crossover boards 1C's and 1.2tl's
Toolfan66
I have spent most of the day working on my new Crossover boards for my 1C's and my 1.2tl's from gimpod (1C's) and DK (1.2tl's). the hardest part is getting through the hot glue to take the inductors off the original boards.. :frown: what a pain in the ****!!
These new boards are awesome to work with and my solding skills are top notch as well,very pleased how they are coming out.:cool:
Sorry Jesse but I had to try it my self..
The solding station was worth every penny and then some, made life much easier..
Doubt I will get them in to take a listen today,but soon..
Will post pics soon...
Post edited by Toolfan66 on
Which soldering station did you get?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I will post pics of the 1C's after the battery charges
Damn, that's pretty... just some seriously top-shelf work.
The upgraded original crossovers are the set Ben did almost two years ago..
Those are sooooo sweet, wish I could get a set for my LSi9's, hint hint...
Nice work Larry!
The crossover of the LSi9 is simple in comparison. Cut a .5" strip of MDF narrow enough to fit through the woofer's hole, and build a point to point crossover on it.Conradicles wrote: »Those are sooooo sweet, wish I could get a set for my LSi9's, hint hint..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
damn that is some cleeeean solder work.
They really did a killer job on laying out those new boards too.design is where science and art break even. -
any concerns with the small inductors located that close to each other in the same direction? it could just be the purist engineer in me but I thought that was bad practice? looks great tho!
Beautiful improvement Larry!
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Looking good Larry. Tony's boards make it easy, don't you think?Political Correctness'.........defined
President of Club Polk -
cincycat13 wrote: »any concerns with the small inductors located that close to each other in the same direction? it could just be the purist engineer in me but I thought that was bad practice? looks great tho!
The inductors are actually at a right angle to each other. However, even if they were in line with each other, it probably wouldn't have any audible effect: Loudspeaker Inductor Crosstalk Measurements
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Two of the inductors were side by side on the original boards.
Nice job TOOLFORLIFEFAN, Now we just need to see the pics for the 1C's“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
are the boards GA yet? or we still testing?
I got all my crossovers in today,and all is working well. I only listened to my 1C's for about half an hour,and moved them out of the way to finish up my 1.2tl's.I was really curious about them since I changed the inductor as well with this setup. Both set of boards work great and really clean them up. I was lucky enough to have two sets of 1.2tl crossovers so I didn't have to take apart the work Ben did for me on my original set,and I can A/B test if I want too.
Again a very fun project..
Thanks again DK and gimpod... -
TOOLFORLIFEFAN wrote: »I will post pics of the 1C's after the battery charges
No offense, but maybe one of these day's and your thought's if it's not to much trouble.
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
I plan on giving them some listening time this weekend...
TOOLFORLIFEFAN wrote: »I plan on giving them some listening time this weekend...
That would be COOL seeing how I'm going to go ahead and order up a run of boards Monday. BTW did you get my last PM ? and if so could you respond by PM I would really like to know what you think.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Please don't rush. Your efforts are too valuable! Please consider waiting until all the beta folks test the boards on all the SDA models for which you have designed your board. Just a friendly caution here.......
I will say this the boards make everything simple to follow and solder together. it seems Gimpods boards will work on most SDA's, I could have used them in my 1.2tl's as well as my 1C's I see no problem in them.
I will say one thing about the inductors,and that is I will be doing it in my 1C's as well. Yes they do make a difference a big one at that.. I'm not sure there is much left that is stock in my 1.2tl's...
For gimpod being a newb "if you will" the guy has done a fantastic job in a short time here.. -
TOOLFORLIFEFAN wrote: »I will say one thing about the inductors,and that is I will be doing it in my 1C's as well. Yes they do make a difference a big one at that.. I'm not sure there is much left that is stock in my 1.2tl's...
Hi Larry!
Nice job! I am a little confused from your post and the pics, which inductor(s) did you replace? Just the big one?
Regards,Carl -
Yes larry, tell us about the inductors.
I plan on doing my 2Bs with these new boards and should probably go with new inductors too.Id like to tackle the whole thing and not have to upgrade something later.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Sorry bout that, Yes I just changed the big inductor with a North Creek 16mH inductor in my 1.2tl's.
Will that work in all the SDAs?SDA-2BTL with custom IC
TOOLFORLIFEFAN wrote: »Sorry bout that, Yes I just changed the big inductor with a North Creek 16mH inductor in my 1.2tl's.
Since we're bugging you with inductor questions... what wire gauge did you use? It looks like North Creek's smallest is 14 and the schematics use 18ga. -
I used 14ga, and yes you can do this to all SDA's.
Looks like my 1C's use the same size inductor as my 1.2tl's (16mH) and my CRS+'s use a 16mH..
