My DIY 2 channel: Next component
I built this crosscut sled. HIGHLY recommended, and you can cut at any angle.
http://www.eaglelakewoodworking.com/post/Super-Sled-Crosscut-and-Miter-Sled.aspx
I have a pdf worksheet on how to build one of those. Some day.
Currently I built a few different angles that I can clamp to the fence. That is how I do my miter cuts. -
I can't say working with Table saw is a dangerous job but I know a lot of people are working on one everyday and an accident can occur any minute with a slight mistake.
If I have to resaw bigger stocks, I will get a band saw. I'll always use a track saw system like EZSmart or Festools for panel cutting or any angle cutting. And I use compound sliding miter saw which can cut 24" panels across for any angle.
You can never be too careful even if you are a regular table saw worker. And kickbacks are typical in table saw system.
For me, safety always comes first before anything else if I have a choice.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Another shop nicety:
The Dust Deputy.
Saw stop to the rescue.
I hope it works when you really need it.
http://www.youtube.com/watch?v=E3mzhvMgrLETrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Looking good so far.
I would only ask, why didn't you use a blank circuit board for the crossovers? It would look neater. -
I was going to ask the same thing. Using pegboard for the crossover reqires more effort than the proper tagboard. It just deminishes the effort made IMHO.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Breadboard wouldn't have the right gauge of hole through. Preprinted PCB's take up too much space since their layouts are generic in nature and I can't keep my leads as short.
I used the pre-printed PCB's from Madisound for my Zaph builds and just not that thrilled. It's a preference thing. -
They are going inside the cabinet:biggrin: -
Breadboard wouldn't have the right gauge of hole through...
That is what the correct drill bit is for. If you can handle a mitre cut, a drill should be fairly easy.:rolleyes:
Guage, BTW has to do with thickness of a material. Diameter is used when describing hole size.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »That is what the correct drill bit is for. If you can handle a mitre cut, a drill should be fairly easy.:rolleyes:
I understand. When I do custom Molex or IDC the holes can handle up to a certain 'gauge':rolleyes: It's just generally how the stuff is referred too. When you go to Digikey, Mouser, Jameco and look at connectors and such they will tell you the size and spacing offset. They will also tell you what gauge wire they can handle.
I'm not exactly sure what the issue is with using peg-board. I have used bread and pre-printed PCB's and my personal preference is not to for X-overs.
If I really wanted to I could use EasyPCB, do a layout and have it printed at PCB-Pool. -
:rolleyes:nooshinjohn wrote: »It just diminishes the effort made IMHO.
While it may not be as neat as a PC board it does not diminish the performance in anyway as long as the coils are oriented to avoid mutual coupling and parts are secured tightly to the board.
btw.I assume you intend to add some hot glue along with the wire ties to keep those components secure. -
:rolleyes:
Hot glue has been used throughout. You probably can't tell from the pic's but the caps are all hot glued together. Doing the x-overs in three sections will eliminate any cross talk because I can space them out. Again pre-printed PCBs end up being a bit of a space waster. If there was any improvement to be gained mechanically, electronically, audibly I sure would have used PCB board. -
Point to point is better than PCB's.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Great job. I wish I had the time to build some Spender SP1 clones :-)
Coming along....
I'm really liking the versatility of the jawhorse. Used it to hold the cabinets so I could flush trim the baffles.
It's been a bear to dado EVERYTHING but well worth it for the structural rigidity it has provided. Plus I believe I have dado's down to a science now so all future builds will benefit. Time to redo my Zaph 3.5's?
Is there a sight with build plans for the Spendor's?
Time is what you make of it. An hour here, an hour there. -
Great project you have here bud, I cant wait to see the finished results
Question _ how does one test a home made speaker ? -
polkfarmboy wrote: »Great project you have here bud, I cant wait to see the finished results
Me either:biggrin:
First is to simply mount the speakers on the baffle, connect the x-overs and play some sweeps/FFT and measure the response. Tweak if needed.
Next I'll dry fit the baffle to the cabinet and clamp. Again sweeps and real program material. If all that is fine it's final glue up. -
Nice looking build you have going there.Hope you have a good mask to deal with all that nasty MDF dust.
Thx.
Yeppers. I have a paint mask with charcoal filtration. Need to find a router with dust colleciton. Try to do as much outside as I can.
The table saw has a cyclone + shopvac. Does a great job. -
Ah, another weekend at home and work progresses on these bad boys. Got really aggressive with the chamfer. I really don't want any restrictions around the drivers and felt I could do better than a simple 45 or round over.
Next is round over the front edge, install the port and terminal cup. Then onto paint. -
