I'm happy,amp can handle these speakers
PolkClyde
PolkClyde Posts: 662
edited February 2011 in Speakers
Jaming to earth wind and fire,coming loud from the Infinity kappa 9. Im very happy my amp and handle them with ease....they can drop to 1 ohm,I heard.
PolkAudioClyde
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    What amp are you using?
  • cjmustang69
    cjmustang69 Posts: 117
    Are you running the Kappa 9s set with the extended bass? It is my understanding when the speakers are set to extended bass is when the ohms can drop to 1 or less.
  • PolkClyde
    TNHNDYMAN wrote: »
    Carver Mono blocs silver 7
    PolkAudioClyde
  • PolkClyde
    Yes,Im running them on extended,not normal, via A pair of Carver Mono Blocs
    PolkAudioClyde
  • cjmustang69
    I have a pair of Kappa 9 speakers also. I have Adcom GFA 565 mono blocs which I had been using to drive them. Overall, I'm very happy with the performance of the Kappas driven by these amps. I also have a pair of Pioneer HPM 200 speakers which I had been driving with a Sunfire Load Invariant amp. This morning, I switched amps and speakers. Been listening to the HPMs driven by the Adcoms. Initial impression is the Adcoms sound very nice with the HPMs.
