I'm happy,amp can handle these speakers
Jaming to earth wind and fire,coming loud from the Infinity kappa 9. Im very happy my amp and handle them with ease....they can drop to 1 ohm,I heard.
PolkAudioClyde
Post edited by PolkClyde on
What amp are you using?2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Are you running the Kappa 9s set with the extended bass? It is my understanding when the speakers are set to extended bass is when the ohms can drop to 1 or less.
PolkAudioClyde
cjmustang69 wrote: »Are you running the Kappa 9s set with the extended bass? It is my understanding when the speakers are set to extended bass is when the ohms can drop to 1 or less.
Yes,Im running them on extended,not normal, via A pair of Carver Mono BlocsPolkAudioClyde -
I have a pair of Kappa 9 speakers also. I have Adcom GFA 565 mono blocs which I had been using to drive them. Overall, I'm very happy with the performance of the Kappas driven by these amps. I also have a pair of Pioneer HPM 200 speakers which I had been driving with a Sunfire Load Invariant amp. This morning, I switched amps and speakers. Been listening to the HPMs driven by the Adcoms. Initial impression is the Adcoms sound very nice with the HPMs.
