Reccomendations for Speaker Wires
I have plenty of respect for Holtz and Cambell, but it's safe to assume the owners of GIK and Real Traps probably know a little more about acoustics. :rolleyes:You better run and tell Jim Holtz and Curt Campbell:rolleyes:
To the OP: if you don't know who those two guys are google them.
Foam by mail is one of many places. If you don't mind working with OC 703 it is a good way to build traps with.
You should show some respect for them too and stop hiding behind their names while you're at it.
http://www.polkaudio.com/forums/showpost.php?p=1487640&postcount=121"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Next time I speak with Jim I'll give him your regards. Jim is the one that told me about Foam by Mail.
If the OP doesn't want to DIY GIK / Aurex / Real Traps all great. -
Jinjuku, I am in NO shape to claim to be audio expert, hence, I am here to get advise from seniors/old timers such as you and others (for audio only though - if you want to discuss software design principles, proj. mgmt methodologies- the bet is on!) It's free country to express opinions, though politely!
Agile suXor... TDD is for girls!
Sorry, just spotted an opportunity to be impolite about something I know something about for a change.
Weren't we talking about speaker cables at some point in this thread...? Let's settle down and focus on the initial reason why this thread exists.
Drunkcaballo, I know there are a few speaker cable shootouts throughout the forums. I'm doing this from my iPhone, so it's a bit difficult for me to search for them right now and copy/paste them into the thread, but they shouldn't be difficult to find. There's lots of good info about the different brands/lines in this forum as well as others. Typically, there's not one simple "this is the best product" solution for someone. It's a matter of taste, because different cables have different conductivity attributes. Your best bet is to try various cables and decide on one. It's not the most cost effective route, but it gives you firsthand experience with the cable and how it will sound with your system.
Audiogon.com is a great resource to pick up some interconnects and speaker cables at great prices. Used ICs and cables are already broken in, so you know right then and there how they are going to sound. Plus if you're only using them for a week or two just to try them out, you should be able to turn around and sell them at minimal-or-no loss from your pocket. Leave your stereo on while you're at work and get your new speakers broken in for now. By doing that, your speakers breaking in isn't going to come into the whole process of new cables. At that point, you want the only potential variable to be your cables.
Hope this helped.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
You must feel quite privileged to use these Gents name whenever you see fit. I hope they know that their names are used as shields and batons on the Internet Forums.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
You mean like when you guys drop Nelson Pass's name? -
It seems to be a good day for fishing. The trolls are already out.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Drunkcaballo wrote: »Alright I just upgraded from my LSi9s to some B&W 805Ds for my 2 channel system. The next upgrade for them is some real speaker cables. Right now I am just using spooled Monster XP wire. I have been looking at some of the Transparent products, but am unfamiliar with what else is out there at similar quality levels. I have heard some transparent cables on these same type of speakers and they really open up with them, so I am already leaning towards them. I plan to buy used from Audiogon. Would be willing to spend somewhere in the $1500-2500 range. Also is there any good source for individual wires? My AV rack is in the corner, so my speakers are not equally spaced from the rack so I will need a ~8 foot cable and a ~20 foot cable.
Do you have any way to reduce the 20' distance?
I've personally found that buying, listening for myself, and then selling and moving on to the next was the best way to find cables and wires that work well with my specific mix of components.
Kimber and MIT have consistently performed well with the broadest assortment of my gear.
The reason I ask about the 20' run is that it will be incredibly expensive to buy, and even harder to resell as the market is broadest in the 8-10' category.
If you do decide to try many brands and listen before you find what works best, you might consider temporarily moving things so you can experiment with and resell 8-10' cables.
If you really can't move things around and don't have the time or inclination to experiment, you will most likely get the best solution within your budget by contacting Joe as F1 suggested above.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Take that $1500 and get some room treatments. Foam by Mail is a great place to source from if you are into a bit of DIY panels.
Room treatments are great suggestion, but not what the OP asked for.
P.S.: Foam is cheap for a reason. Even if you don't buy them, GIK and RealTraps should be researched before considering any other method of treatment.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
If you meant I put both NP and JC in my signature line from one of DIY Audio threads, it's a Big Difference to what you did.
I have never once mentioned or quoted NP or JC names or what they said on the forum fight like you did. It's the obvious and everyone knows.
So, why did I put the NP and JC in my signature line.
Coz I like what they said in one of the DIY Audio Thread. It's taken from one of the JC Burning Amp Thread, If I remember correctly.
They are the Pro. They know what they doing. And they both knows what is a good sound and how to measure and model. And from what JC is doing, he was trying to measure the noise from resistors at really incredible levels
In any case, I don't use these two Gents names to fight or abuse their names. But they reminded me whenever I see it, Good Engineering Doesn't come with with blind eyes and how Pro are doing it at down to earth levels and doesn't talk much. Whenever I see it, it reminds me to talk less and post less in the nonsenses threads and stay away from it. In a word, what they said is a Kool Aid for me when I lose a hold of reality. :biggrin: And it brings back a sense of what can be measured, modeled and possibility. What they said makes a Huge Sense to me!
Anyway, I would like to see if you can find that I used NP or JC names in the food fight like you did. Or anyone using their names in CP in the same manner as you did for this matter.
It's time for some post and thread digging?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
obviously we can not have a conversation about this without people acting like morons. for the OP, you have to take all the info and extrapolate what to try, the cool thing is that there is nothing wrong with trying different things.
If your going to experiment with cable/wie and what improvements they can make, try bigger guage first of course, then some of the reputable brands quoted here. Go the used route and save some $ as experimentation can get pricey. do it over time, it took me years to put together a system I like and I still play around.
people that hear a difference w cables and wires hear it and have differing opinions, others that don't don't, yet have an odd fascination that others dare to say there is a difference and take umbrage to it in a fit of what I call a lack of self worth.
I am in the cables make a difference camp, if others want to say I hear something that isnt there, oh well. I trust my own judgement and spend my discretionary dollars by what my ears tell me, not what others think is accurate.
If you get nothing else out of this, trust your ears, they are the ones you're trying to make happy anywayLiving Room 2 Channel -
Upstairs 2 Channel Rig -
