Reccomendations for Speaker Wires
Drunkcaballo
Alright I just upgraded from my LSi9s to some B&W 805Ds for my 2 channel system. The next upgrade for them is some real speaker cables. Right now I am just using spooled Monster XP wire. I have been looking at some of the Transparent products, but am unfamiliar with what else is out there at similar quality levels. I have heard some transparent cables on these same type of speakers and they really open up with them, so I am already leaning towards them. I plan to buy used from Audiogon. Would be willing to spend somewhere in the $1500-2500 range. Also is there any good source for individual wires? My AV rack is in the corner, so my speakers are not equally spaced from the rack so I will need a ~8 foot cable and a ~20 foot cable.
RTi A7: Front Channels
CSi A6: Center Channel
FXi A6: 4 Surround speakers
JL Audio Fathom 212 Sub
Onkyo 706: Receiver/Pre-Amp
XPA-3: Front Channel Amp
Samsung 50" Plasma: PN50A450
Samsung Blu-Ray
Pre-Amp: Rogue Magnum 99
Amp: B&K Reference 200.2
B&W 805D
DSW Pro 400 Sub
Pro-Ject RPM 1.3 Genie Record Player
Pictures: http://www.polkaudio.com/forums/showcase/view.php?userid=94116
I suggest a nice pair of Kimber Kable 8tc's, replace all Interconnects with Hero's and call it a day.Dan
With that budget I would go with revelation audio labs Testament Cryo-Silver™ Reference Loudspeaker cables.(My next upgrade)...Maybe not the best choice though since you want different lenghts for each speaker.Check out audiogon for some of those 8tc's.You cant go wrong with those.
link to the testaments. http://revelationaudiolabs.com/cables-loudspeaker/index.htmSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I would run two equal length runs and loop back the shorter run.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
MIT Shotgun's. Contact Joe Abrams on Audiogon.
How much of a difference do speaker cables make? I had a very nice system using regular 12-gauge speaker cable and it sounded fantastic to my ears, what are the benefits of more expensive speaker cable?
crazytasty wrote: »How much of a difference do speaker cables make? I had a very nice system using regular 12-gauge speaker cable and it sounded fantastic to my ears, what are the benefits of more expensive speaker cable?
They look pretty. -
I second the MIT option.Michael
NORTH of 60° -
Drunkcaballo wrote: »Alright I just upgraded from my LSi9s to some B&W 805Ds for my 2 channel system. The next upgrade for them is some real speaker cables. Right now I am just using spooled Monster XP wire. I have been looking at some of the Transparent products, but am unfamiliar with what else is out there at similar quality levels. I have heard some transparent cables on these same type of speakers and they really open up with them, so I am already leaning towards them. I plan to buy used from Audiogon. Would be willing to spend somewhere in the $1500-2500 range. Also is there any good source for individual wires? My AV rack is in the corner, so my speakers are not equally spaced from the rack so I will need a ~8 foot cable and a ~20 foot cable.
Thats alot of money for cables budd
I would put the cash to somthing in the amp department for the biggest sonic improvement
Why not go with nordost cables, they have really good reviews in the cheaper lines they reproduce like the blue heaven -
LOL!They look pretty.
Seriously, how about these for longer runs:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=109-062
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=100-025
and this for shorter runs:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=100-021
Put the money saved into better speakers and/or a microphone plus measurement software to optimize your in-room response. -
LOL!
JCandy, I am with you. btw, could you recommend some names of software products to measure and optimize in-room response? Thanks. -
A very popular (free) package is Room Equalization Wizard (REW):JCandy, I am with you. btw, could you recommend some names of software products to measure and optimize in-room response? Thanks.
http://www.hometheatershack.com/roomeq/
You'll also need a (calibrated) microphone, mixer, sound card, etc. A good description of the hardware requirements is here:
http://www.hometheatershack.com/forums/rew-forum/42829-current-rew5-hardware-recommendation.html -
wow, whole new adventure in sound tuning! Thanks for the info. Wish some expert here creates cheat sheet or so explaining how to do this without spending much time. Will look into it. -
An SPL meter and a tape measure is all you need to set levels and delays. There is a steep learning curve and a fair amount of money needed to be spent to use REW(which I have used) REW is better suited to designing speakers. Take some pictures and post them. The guys here can help you out with speaker placement. Also move your sub around if you can for best sound.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks for all the recommendations everybody. Creating a nice long list for me to research...and yes an amp upgrade is in the not so distant future once the cables and sub are upgraded....
Samsung Blu-Ray
B&W 805D
DSW Pro 400 Sub
Pictures: http://www.polkaudio.com/forums/showcase/view.php?userid=94116 -
Sounds good. Will do it once things (setup) settles down. Thanks. -
Parts express has an SPL meter for around $20 if you need one.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=390-722Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
LOL!
I bought some of this when PE was blowing it out even cheaper than they have it now. It's not good cable in my opinion. For the price it's ok, but for some bizarre reason they put a non-conductive polyester core in the middle of the copper wire. I assume it's for marketing reasons (makes the cable appear to be a lower gauge than it really is) and they try to spin some crap about the polyester is a dielectric that improves the signal? Doubt it. It just makes the cable a pain to work with. -
For speaker cables look at Kimber 8pr and use there SBAN connectors and buy from audioadvisor.
Interconect maybe Kimber Hero hb. -
Take that $1500 and get some room treatments. Foam by Mail is a great place to source from if you are into a bit of DIY panels.
In case you missed it, the OP is looking for cable upgrades.
I'm in with the MIT camp. Good luck and welcome to CP, Drunkcaballo.
I know he is asking about cable upgrades. You better tell Ben that also. I mean what the hell is he doing recommending getting a tape measure and SPL meter:rolleyes:
Mr Glide and Jcandy obviously don't under stand either. Better get on them.
Don't forget Polkfarmboy, he recommended an amp. Try not to be so selective.
Now if you are done derailing the thread... -
Why are so many of the "regulars" on this forum so consistently rude? What purpose does it serve?I'll decline to challenge this load of bs. That's your MO, but by all means, continue on with your hissy fit.
I have used the AQ 14/2 wire. Very nice sounding considering how cheap it is.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Its definitely not easy to work with. Honestly, despite the fact that this wire is very cost effective and more than adequate for most any home audio application, I am nevertheless moving to the use of North American and European products as much as possible.On3s&Z3r0s wrote: »I bought some of this when PE was blowing it out even cheaper than they have it now. It's not good cable in my opinion. For the price it's ok, but for some bizarre reason they put a non-conductive polyester core in the middle of the copper wire. I assume it's for marketing reasons (makes the cable appear to be a lower gauge than it really is) and they try to spin some crap about the polyester is a dielectric that improves the signal? Doubt it. It just makes the cable a pain to work with.
Is there a preferred US/Canadian/European brand of wire that is cost-effective? -
Probably because we all have nothing better to do than write endless posts in one audio company's forums... :biggrin:- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Where have you been? The facts that Juju is always out to stir the pot around here. And the fact that the admin/mods have not banned him yet somehow escape you? :rolleyes:--Gary--
Jinjuku, I am in NO shape to claim to be audio expert, hence, I am here to get advise from seniors/old timers such as you and others (for audio only though - if you want to discuss software design principles, proj. mgmt methodologies- the bet is on!) It's free country to express opinions, though politely!
As usual, more awful advice from you.
http://www.gearslutz.com/board/bass-traps-acoustic-panels-foam-etc/347215-foam-factory-foam-mail-dilemma.html
http://supersoundproofing.com/forum/index.php?topic=2278.0"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
if you budget does not allow for the newer MIT's,, try some MIT Terminator 2 with the grey color boxes.JC approves....he told me so. (F-1 nut)
You better run and tell Jim Holtz and Curt Campbell:rolleyes:
To the OP: if you don't know who those two guys are google them.
Foam by mail is one of many places. If you don't mind working with OC 703 it is a good way to build bass traps with. For higher frequency traps you simply don't need a ton of dampening.
Don't even know if you need traps. That's why Ben's suggestion is the first thing to do. Have to find out what the room looks like to your speakers first before you take any extra measures.
