Quick cable shoot out: MITs and AQs
Erik Tracy
Erik Tracy Posts: 4,673
edited February 2011 in 2 Channel Audio
I had the day off and decided to do a quick and admittedly informal IC cable shoot out.
1) AudioQuest Columbias w/ 48dbs
2) AudioQuest Jaguars w/ 36dbs
3) MIT CVT Terminator 1s
4) MIT Shotgun S3s
Source component:
Marantz SA-KI Pearl SACD player
Amplification:
Musical Fidelity A5 Integrated Amplifier
Speakers:
B&W CDM 1NTs, with an Epik Valor sealed sub
Speaker cables:
MIT Shotgun S2s
No bass management: just preouts from the MF to the sub using the low pass on the back of the sub.
Source Disc:
Steely Dan's Aja on SACD
All the cables have been in my system between various components: BDP, SACD, CDP and have been burned in.
I kept the MF A5 at the exact same volume position when swapping between cables by powering off the player and amp.
The MIT Shotgun's impedance switches were set to 'high' (above 90Kohm) as my A5 has 220kohm for line level input impedance.
As I said very informal:
* MIT CVT T1s: highs seemed a tad recessed and rolled off. Emphasis was bass heavy (strong actually).
* AQ Columbias: brightess of the bunch - lots of detail up top. Bass sounded a tad 'loose'.
* AQ Jaguars: surprisingly good - liquid highs with good detail. Ooodles of mid bass clarity and thump.
* MIT Shotgun S3s: nicely balanced from top to bottom, bass is well defined and controlled, warm (biased?) midrange, very very slight high end roll off.
I would not generalize what my impressions are for any other system. And this was just for one source disc - and not over any extended listening sessions.
ymwv (you mileage will vary).....:smile:
I think I'm going to spend more time with the Jaquars (surprise there) and the Shotguns.
Post edited by Erik Tracy on
  • olilugo
    olilugo Posts: 405
    Hi Erik, can you tell me what is your cross over setting for your SUB?
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • zingo
    zingo Posts: 11,258
    I like a quick shootout like this and thanks for putting in a little time to do it!
  • Erik Tracy
    olilugo wrote: »
    About 68Hz.
    The B&Ws have a -3db point at about 60Hz.
    I've played with the xover and 68Hz seems to be 'it' for now.
    I'm still playing with sub direction - I've read you don't want to 'point' your sub directly at the listening spot, so I'm adjusting the angle bit by bit.
    I'm in a 'happy place' right now.
  • mantis
    mantis Posts: 17,313
    Very cool shootout and thanks for taking the time to write about it.
    I think the Jag's are fantastic IC's , they really lack nothing. For the money I don't think there is a better IC. It would be nice if you had a pair of CV8's to compare to the MIT's in a true VS.
    Dan
  • Erik Tracy
    mantis wrote: »
    Alas...at one point I did have CV4.2s (48 dbs), but parted with them when an amazing offer and swap came up for the Shotgun S2s....I really do like these for my setup.
    Just one stop on the path....
  • olilugo
    olilugo Posts: 405
    Hey Erik Thanks for the replay it seem I am going in all kinds of directions. I want to beef up my PC sound and I am looking to improve my sub in my HT.
    The sub I have today is a Velodyne DLS-3705R, I am very pleased with it for movies; the rumble shakes everything in the house.
    When it comes to music, I get almost nothing from the sub and most of the bass is coming from the front speakers, while it is very fast and tight it is not as wow as probably would sound coming from the 12in sub.
    I have it set to 80 Hz cross over but I wanted to see if the sub would take more of the bass and Dump sounds but I want them to be tight and precise and not just the rumble.
    I was hoping you tell me that you have your cross over at around 150 Hz but instead you are lower than mine… I think I am going to try setting it higher and lower and compare the results.
    I am hoping that I can find a way to set it and not have to purchase a new sub. But at this point I don’t know if it is the Sub or the AVR that it is just not sending the signal properly in Stereo mode.
    I have tried increasing the signal by +3db when in stereo and it help just a bit but not much…
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  • Ern Dog
    Ern Dog Posts: 2,237
    Thanks for the review. I haven't had a chance to hear AQ's yet. I also had a similar take on the shotgun IC's I demoed.
  • Erik Tracy
    olilugo wrote: »
    I was hoping you tell me that you have your cross over at around 150 Hz but instead you are lower than mine? I think I am going to try setting it higher and lower and compare the results.
    I am hoping that I can find a way to set it and not have to purchase a new sub. But at this point I don?t know if it is the Sub or the AVR that it is just not sending the signal properly in Stereo mode.
    I have tried increasing the signal by +3db when in stereo and it help just a bit but not much?
    Try posting your question/problem in the subwoofer forum.
    What AVR do you have - depending on how it operates, what you describe as "Stereo mode" may be a mode where the sub output turns off - which might explain why you get no sound from the sub for music.
  • ben62670
    ben62670 Posts: 15,969
    I too felt the highs roll off with the MIT's that I have tried. The sound stage wasn't as good either. Bass was fuller, but I ended up prefering the AQ CV4's. Much more open IMHO.
    Ben
  • Erik Tracy
    ben62670 wrote: »
    Right now, I am really digging the 'synergy' I'm getting with the AQ Jaguars and the MIT Shotgun S2 speaker cables.
    I had the Jaguars relagated to doing AVR to Integrated Amp preout duty, but moved them to my SACD player....I'm in a 'happy spot' right now.
    The bass/mid-bass is really sweet - balanced nicely thru the treble as well.
    As Goldilocks would say "juuustt right...." :biggrin:
