Phase Switch
edited February 2011 in Troubleshooting
Just received my PSW110 and need some info on the phase switch. What is it for and on which setting should it be on? I currently have Monitor 60s along with a CS1 all driven by an Onkyo 604. Any help would be great.
Post edited by Cocahoe on
    The phase switch does exactly what it's name sounds like; it changes the phase. This is used to put the sub in phase with the rest of the speakers. If you have the sub at the front of the room, you should normally have the phase switch in the "0" position. If it's at the back of the room, then you would use the 180 setting.
    A bit more of an explanation here (and google's your friend) http://www.crutchfield.com/S-16wmxdpKG7s/learn/learningcenter/home/speakers_faq.html#phase
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
Welcome!
Welcome!
