Phase Switch
Cocahoe
Just received my PSW110 and need some info on the phase switch. What is it for and on which setting should it be on? I currently have Monitor 60s along with a CS1 all driven by an Onkyo 604. Any help would be great.
Post edited by Cocahoe on
The phase switch does exactly what it's name sounds like; it changes the phase. This is used to put the sub in phase with the rest of the speakers. If you have the sub at the front of the room, you should normally have the phase switch in the "0" position. If it's at the back of the room, then you would use the 180 setting.
A bit more of an explanation here (and google's your friend) http://www.crutchfield.com/S-16wmxdpKG7s/learn/learningcenter/home/speakers_faq.html#phaseTurntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
