Psw202
ianc99
ianc99 Posts: 3
edited February 2011 in Troubleshooting
My PSW202 subwoofer has no power. Hopeing it's just a fuse but don't know where it is located.
Post edited by ianc99 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2011
    Hello,
    The fuse for the bass amplifier is on the other side of the input plate. To remove it you would unplug the AC power cord and take out the screws that go around the circumference of the amplifier's input plate. Then use a putty knife to loosen the plate from the sub's cabinet and pull the complete amplifier away from the cabinet. The fuse will be located near where the AC power cord goes through the input plate. There will be two wires going to the internal woofer, they have clips on them that lets you remove them.
    In all likelihood the amplifier will need to go to Polk's service center to be repaired. Give Polk's CS a call on Monday at 1-800-377-7655 and they can give you more details.
    Regards, Ken
  • ianc99
    ianc99 Posts: 3
    edited January 2011
    Hello,
    Regards, Ken
    Thanks Ken. I was afraid of that. $$$$$$$
  • [Deleted User]
    edited January 2011
    I believe the repair is fairly reasonable, it used to be around $60.00, but may have changed. Well worth it, in my opinion.
    Cheers, Ken
  • ianc99
    ianc99 Posts: 3
    Cheers, Ken
    Thanks Ken
    I'll have to find a dealer here.
    Cheers
    Ian
  • dgodbold
    dgodbold Posts: 1
    My PSW202 just croaked too. opened it up fuse is blown. hoping a trip to radio shack will solve the problem. If not, the "new"version of this sub is going for 99 bucks on amazon! might want to consider that before paying 60 bucks to fix the old one
