Welded, (not soldered) cables.
    edited February 2011
    arun1963 wrote: »
    Don't mean to ruffle feathers, carry on.
    Then why post at all ??
    I can't say one way or the other if any sonic benefit is to be had, untill I actually try it. Thats the key with all subjective tweeks, you have to try some to offer up an opinion.
  • quadzilla
    quadzilla Posts: 1,543
    Face wrote: »
    Too bad they use brass termination.
    That was exactly the first thought that came to my mind, followed immediately by "bananas? really?" I've hit the point that I will use only bare wire or spades, and in that exact order. I hate bananas now. Unless they're in my cereal, that is.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • virtualdean
    virtualdean Posts: 286
    arun1963 wrote: »
    Excuse my ignorance, but the debate on sonic value of soldered vs welded is a bit humorous on two fronts.
    I can hear better than you and my equipment is at a level that lets me hear the difference. Really?
    Please feel free to jump in with your opinion on the next magic cable/no magic cable speaker cable wars....You will be jumped on by THOUSANDS! :)
    Deserves got nothing to do with it. :biggrin:
  • arun1963
    arun1963 Posts: 1,797
    Yeah I know. However, I'd stay out of the cable threads, I'm not a ****. :biggrin:
