rabbits hole rig?
tavogee
tavogee Posts: 91
edited March 2011 in Electronics
What is a rabbit hole rig, I see it all over?
LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
Post edited by tavogee on
«1345
    edited February 2011
    I'll let the veterans take this but if you want to do some research yourself...look up some of Ted's threads (reeltrouble1)!
    cnh
    mhardy6647 Posts: 35,238
  • cstmar01
    cstmar01 Posts: 4,424
    Don't have one yet, want one though, just always scary to take that first jump. Sometimes you just need a push.
  • Big Dawg
    Big Dawg Posts: 2,005
    tavogee wrote: »
    Once you jump into the rabbits hole, there's no telling how deeply you'll fall.
  • tavogee
    tavogee Posts: 91
    What is a rabbit hole rig?
    It's not a rabbit hole rig.....it's more so a rig in a rabbit hole. I had the same confusion with Ted when he had his woodshed rig. I guess you have to know Ted a bit to understand his vocabulary. Just terminology folks. Think about what a rabbit hole is and all that goes with it, you'll figure it out.
  • thsmith
    thsmith Posts: 6,082
    My definition is - It is taking the a long trip less traveled by most. Once you get started it don't stop until you find audio bliss, hopefully before running out of money.
  • tavogee
    tavogee Posts: 91
    Now that makes sense, I am still laughing about the running out of money part. SO IS THE RIG, ALL THE EQUPMENT?
  • tavogee
    tavogee Posts: 91
    Also, who is ted?
  • madmax
    madmax Posts: 12,434
    tavogee wrote: »
    Also, who is ted?
    Ted just is.
    Vinyl, the final frontier...
    madmax wrote: »
    Ted just is.
    ...and always will be.
    Ted is Reeltrouble....you guys are slow today.:smile:
  • tavogee
    tavogee Posts: 91
    Will someone please answer my questio?
  • tavogee
    tavogee Posts: 91
    Who is ted?
  • vc69
    vc69 Posts: 2,500
    tavogee wrote: »
    Who is ted?
    tonyb wrote: »
    Ted is Reeltrouble1 or RT1. He is so far down the rabbit hole that the rabbit is bleeding.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • tavogee
    tavogee Posts: 91
    Im sorry but I do not understand.
  • tavogee
    tavogee Posts: 91
    Is Ted an expert at audio?
  • thsmith
    I am starting to smell something.
    tavogee, welcome to CP but get back on topic. Several options provided to you. THoughts?
  • tavogee
    tavogee Posts: 91
    Im sorry but you lost me, I am just trying to get some advice/recommendations on setting up a system for playing my records, cds, tapes etc. I don't know which amp, processor, receivers to buy. I will not be using it for movies (music only). This setup has to sound very good. I know nothing about tubes, etc. I don't even know if a sub is needed for music. It must have good pier.
  • thsmith
    tavogee wrote: »
    Lets start with what you now, room dimensions hxwxl ?
  • vc69
    vc69 Posts: 2,500
    sumthin stinks.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
    tavogee...? How well do you know ALICE? The Mad Hatter?...
    I thought we pretty much answered your questions above!
    Forget about the Rabbit Hole and start a new thread if you want advice about a new system in EARNEST?
    cnh
  • FTGV
    FTGV Posts: 3,650
    tavogee wrote: »
    An evil, dark sonic Hell where tubes are said to rule.:wink:
  • newrival
    newrival Posts: 2,016
    Whoa... this thread got weird. And no, no one answered his question directly.
    Could you all be any more cryptic?
    rig: kit, gear, system, etc. Its just a synonym for your setup.
    rabbit hole: This is an Alice in Wonderland reference
    exerpt from Alice in Wonderland:
    "[After spottotting the white rabbit, Alice] ran across the field after it, and fortunately was just in time to see it pop down a large rabbit-hole under the hedge.
    In another moment down went Alice after it, never once considering how in the world she was to get out again.
    The rabbit-hole went straight on like a tunnel for some way, and then dipped suddenly down, so suddenly that Alice had not a moment to think about stopping herself before she found herself falling down a very deep well.
    Either the well was very deep, or she fell very slowly, for she had plenty of time as she went down to look about her and to wonder what was going to happen next. First, she tried to look down and make out what she was coming to, but it was too dark to see anything... Down, down, down. Would the fall never come to an end!"
    It's an metaphore used to describe the nature of embarking on a new adventure. Here in the forum it seems often to be used with implied allusions of getting caught up in the journey as well as sometimes used synonymously with the "slippery slope" idiom. That is to say that even if treading lightly at first, you can quickly find yourself quickly sliding into the depths of the adventure (in this case with stereo gear). This is typically associated with the amount of money spent and so some here will associate that monetary element as well.
    Simply put: the rabbit hole is the "audio journey," and sometimes you end up farther into it than you initially anticipate. Most of the time your wallet finds the bottom before you do ;)
  • thsmith
    thsmith wrote: »
    newrival wrote: »
    I thought I replied pretty directly.
  • newrival
    thsmith wrote: »
    indeed you did. I mustve overlooked it while scrolling through
  • megasat16
    megasat16 Posts: 3,521
    Actually, a rabbit hole is a place you don't know where it leads and you don't know where you gonna come out at the other end.
    Enjoy this hobby! And watch out for your wallet! Tubers are a common encounters in the rabbit holes, so it says.
    And where is Ted anyway? I think he hasn't posted here for a while?
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    tavogee wrote: »
    Now that that is solved, I have a question:
    What is a questio ?
  • newrival
    megasat16 wrote: »
    Actually, a rabbit hole is a hole dug by a rabbit. :wink:
  • halo71
    halo71 Posts: 4,638
    tavogee wrote: »
    What??? :confused:
    --Gary--
  • george daniel
    george daniel Posts: 12,096
    To the OP,, to get to the rabbit hole,,you must first enter the woodshed.
