Newbie here, never had good speakers
124»
  • newrival
    newrival Posts: 2,017
    edited February 2011
    man, I had issues finding a solution trying to Pio Elite AVR. it was .75" too big for nearly everything I had or could find. Even worse was trying to find something to house my CS1000p! :biggrin:
    Is it possble, scott, to make that lower compartment directly under the TV taller?
  • ScottL79
    ScottL79 Posts: 48
    thats what im hoping, i just not sure how im gonna do it to make it taller. like i said, the pieces arent just screwed together, they are glued or something... not sure how i would take it apart.
  • ScottL79
    ScottL79 Posts: 48
    according to specs on the Onkyo, it is 6.9" tall, my opening up top is EXACTLY 6.5"... i wonder if i remove those feet on the bottom of the reciever if it would fit? im trying to "modify" as little as possible on this thing..
    anyone have a onkyo 608 or similar and can measure it without the feet? also, would removing the feet be a bad thing? are there fans or vents underneat where it needs the gap?
  • Earthy
    Earthy Posts: 488
    You have to leave some room for it to breathe. It probably needs at least an inch above it. The top is pretty much continuous vents.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • ScottL79
    ScottL79 Posts: 48
    Earthy wrote: »
    was afraid of that. I guess Im just going to have to tear into this thing or put everything below in the doors like I dont want to.
  • ken brydson
    ken brydson Posts: 8,988
    Earthy wrote: »
    Plus Oinkers notoriously run hot. I'd say more than an inch is needed or install a fan. Just my .02
  • Slinger182
    Slinger182 Posts: 512
    ScottL79 wrote: »
    This should get it apart for ya pretty quick.
    Buying gear to fit in your entainment center is much harder than buying an entertainment center to fit your gear.
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • ScottL79
    ScottL79 Posts: 48
    if I were to put the Onkyo underneat and hide it, is there any kind of infared or some deally i can hook to it and have it up visable, so that i can control it with remote without always opening the doors?
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    ScottL79 wrote: »
    you mentioned earlier that you were not really great w/ woodworking skills and that this piece of furniture was an anniversary gift.... that being said I would not want to hack into it and have the wife upset. Let her decide where another spot in the house would be ideal for it and ha ve her shop w/ you for another entertainment center that works for your equipment and meets w/ her design sense.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    TNHNDYMAN wrote: »
    Very well said, I was actually considering the same direction.
    It's such a nice piece and wood working skills not quite being where you'd hope them to be, I'd also recommend a dedicated H.T. display/cabinet/console and recommission the lovely gift you presented to your wife.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • ScottL79
    ScottL79 Posts: 48
    Geoff4rfc wrote: »
    well that sounds good, but I just bought this 47" Vizio 240hz tv about a week ago. I spent weeks researching and finding the largest and best tv I can that will fit inside this thing... had I done that, I woulda gone bigger tv :)
  • Geoff4rfc
    ScottL79 wrote: »
    Where did you get the Viz? Most places have a 30 day return policy. I bought my first 42" at my local Video Only, within a week, I complained of some viewing problems and they let me upgrade to a better 42", I just paid the diff.
    I have a 50" now and would eventually like to upgrade to a 60", wall mount baby, wall mount.
    You say it's been just under two weeks, give it a try to see if you can return or exchange for something bigger :wink:
  • ben62670
    ben62670 Posts: 15,969
    Get a wall mount for the TV at partsexpress.com
    Put the receiver on the top of the entertainment center.
    Ben
  • Geoff4rfc
    ben62670 wrote: »
    That's not a terribly bad idea however.........using the armoire for housing the electronics would be slick, especially since you can close it up. But finding a place to mount the new center speaker may pose another problem, and I wouldn't think you'd want the armoire too close to the wall mount as they would detract from one another.
    Unless of course, you set the armoire off to the side a ways from where the tv would be mounted, display another "like" piece of furniture such as low stand beneath the wall mount in order to display the center speaker.
  • ScottL79
    ScottL79 Posts: 48
    well knowing my wife, this all isnt going to fly. Im going to get a cs2 first hand and see what I can come up with. I was playing around last night and looking at it, i really think i can make this work. hardest part will be finding stain and wood to match this... ill post pics.
  • Geoff4rfc
    ScottL79 wrote: »
    You go Bro. The CS2 is a beast, makes my 50" look like a 32 but what the hey, it's all about the sound, aesthetics are merely a bonus :smile:
  • TNHNDYMAN
    hope you have a pre-nup and a good lawyer ;) Just giving you a hard time... if you can make it work go for it. Don't let my name interfer with the fact that most woodworkers have forgotten far more than I'll ever learn. I'm the same way and like to try to figure it out myself at times it works out great and others.... well not so much. Good luck!
  • inthewoods
    inthewoods Posts: 54
    I have 6 1/2" under our 58" and the CS2 fits nice due to the sloped back. The 608 is on the right and it puts off the heat so a tight space might not be good even thought it has an internal fan.
    Sorry for the dark picture (yes, the M70's have been moved :wink:)
    Panasonic 58" Viera S2 Plasma | Onkyo TX-SR608 | Monitor 70 Series II | CS2 | PSW505 | RC60i
  • MCCLIPSE
    MCCLIPSE Posts: 176
    Geoff4rfc wrote: »
    Just got the 70's last week. AWESOME sound for the money. I love their big monolithic design. They really make a statement for less then $400 shipped.
    Truck system so far...
    2007 Dodge Ram 1500 quad cab Hemi
    Kenwood KDC-X492 HU
    MM651 coaxials in doors
    Family Room:
    Panasonic TC-P50G25 50" Plasma
    Panasonic DMP-BD655K BDP
    XBOX 360 250GB
    Harman/Kardon HK3480(on loan)
  • Geoff4rfc
    inthewoods wrote: »
    Those internal fans don't do a thing for dissipating the heat that comes out. I have an 807 and I got a link for these from a guy on the AVS forum....
    http://www.buyextras.com/evavcoblfanf.html
    I have two for the summer when things are really hot, but only use one during the winter, works great.
