High current AMP
PolkClyde
I'm looking to upgrade to an High current Amp, that doesn't have trouble driving a(Low ohms load) any speaker.. say,a speaker system like the Infinity Kappa 9.. what you say guys? of course,that won't break the bank.
PolkAudioClyde
Post edited by PolkClyde on
Got a Budget?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
How about the Parasound HCA-1500A? There's one for sale on Audiogon for $500. 315wpc @ 4 ohms, 60 amps peak current.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I was in the same boat with some Martin Logans. They would shut down Adcom 555's like they were candy (i had two, tryed both same problems). I picked up an Anthem MCA 20 and couldnt of been happier.
The Anthem was leaps and bounds better than the Adcom in all ways that I could tell, from being able to handle the load from the stats, to the sound quality, just a brilliant amp. You should be able to find one from $5-600 used. I had a custom tube pre on the front end, one of those setup's I should of never sold.
Good Luck.
DaveOnce again we meet at last. -
Odyssey StratosLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
B&K Reference 200.2 and many older B&K amps in the 200 watt class are 75 watts PtoP current.
Useful thread: http://www.bkcomp.com/fileadmin/content/bk_support/FAQ/Previous%20Amp%20Specs.pdf
Classe, Higher wattage Parasound...
Many threads on here discussing high current amps for driving SDA's..... ><////(*> -
Infinity Kappa 9's are murder on amps, often times they get below a 1 ohm load on some passages and fry your amp. Sunfire load invariant amps work well on those but are pricey.
A great option for any difficult speaker loads. -
Amperes P2P...B&K Reference 200.2 and many older B&K amps in the 200 watt class are 75 watts PtoP current.
I have one. I was shocked at how much that sweet amp could muscle up.More later,
Tour...
Vox Copuli
The M6PRX by Musical Fidelity states its 140 current for peak to peak, and 85 amps.
I've heard it before and it was very very nice sounding in the rig it was in. 3400 new, never seen one used before. -
Carver Silver 9t or 7t will drive any speaker with ease if you can find a pair.
