Headsets
squeeb
OK, not my area of expertise. My son is wanting a headset for his birthday. He has a PS3 and will use it mostly to play COD. Any suggestions? I would like to stay around $50 - $100.
Thanks, as always, I appreciate your help.
7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
Post edited by squeeb on
I bought my step son this one for his 360 (although the link is for the PS3 model). He went on for weeks about how awesome it was. Guessing you can get a better price if you look. Turtle Beach makes good headsets- they also have a couple of others that are a bit cheaper.
http://www.turtlebeach.com/products/ps3-gaming-headsets/ear-force-dpx21.aspxMy Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
if all ehs doing is gaming:
stereo: Razer Carcharias
Dolby 5.1: tritton AX 720
If hes into music I'd suggest some Beyerdynamics because they have great musicality and clarity but enough bass for movies and games. Plus you could always add a JVC SU-DH1 for the 5.1 surround in the future. way cool.design is where science and art break even. -
I second the Tritton AX-720's. They are phenomenal for the price ($130).
If your son is of age where he can appreciate a good set of cans, I would absolutely spend the extra $30 to buy these. They are especially useful for a game like COD where he'd be able to pinpoint footsteps and gun shots.
Everyone I've steered towards these has been amazed. -
If you want to save some money XBox has a new one. I personally picked one up and it works great. Just make sure to get the black one- the old ones were grey and they suck.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6696304&CatId=5766My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
I've found these to be the absolute BEST headphones for the price (consider the price point):
$11--can't beat it!
http://www.amazon.com/Philips-Neckband-Headphones-SHS5200-28/dp/B003CJTR8M/ref=pd_sim_e_1
$13--
http://www.amazon.com/Philips-SHS3910-27-Neckband-Headphones/dp/B000QS0ZVU/ref=sr_1_2?ie=UTF8&s=electronics&qid=1297688226&sr=8-2
Here's a more expensive pair for $45--not sure what the difference is, if any:
http://www.amazon.com/Philips-HS500-Behind-Headphones-Neckband/dp/B00005OTG6/ref=sr_1_3?ie=UTF8&s=electronics&qid=1297688193&sr=8-3TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Couple of different factors to take into account. If all he wants the headset for is to communicate with others on ps3. The turtle beach headset through gamestop is fantastic.
http://www.gamestop.com/ps3/accessories/turtle-beach-ear-force-pbt-bluetooth-communicator/84519
If he wants something to listen to ALL sounds out of the ps3 (communication, sound effects, music, etc) turtle beach again, but different abilities.
http://www.gamestop.com/accessories/ps3-turtle-beach-px21-headset/75204
This set requires you to be no greater than the length of the cord away from the ps3.
There are also a few offerings of Turtle Beach headsets that are like the one above but are wireless. Those typically are around 150-170 though. And im having a hard time finding a good link at the moment.
Turtle beach has proved itself time and time again when it comes to headsets for consoles. Razer is good as well but I prefer to keep them on my PC systems. -
OK, not my area of expertise. R4 3DS card My son is wanting a headset for his birthday. He has a PS3 and will use it mostly r43ds to play COD. Any suggestions? I would like to stay around $50 - $100.
Thanks, as always, I SuperCard 3DS appreciate your help.
hanks to Sennheiser's expertise as a global leader in electro-acoustic, PC 350's sound perception is so precise, that you will literally feel like you're in the game. -
What about Skull Candy? They make pretty good head phones. This one is made for the PS3 and has voice comunication.
http://www.skullcandy.com/shop/g-i-ps3-gaming-headset-black-red.html
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
