Question for all you projector guys.
jaritta
jaritta Posts: 277
I am building a ht room, my dimensions of the room are about 15-17ft wide by 20 long. I want to put the projector on my (wide wall the 15-17ft wall)My room is square and i have duct work running about a foot off of the wall(wide wall) i want to put the screan on, I can put the screen on the wall without duct work infront (the other wide wall) I am wondering about the placement of the projector and if i will be able to do a flush mount on the celing, and shoot under the duct work and onto the wall. the duct work after it is finished will hang about 12in off of the celing. I am looking at putting about a 100 in screen with the epson 8700ub. Any thoughts on if this will work?
I can put it on the other wall oposite of the wall with the duct running along it, but i plan on having a bar next to that wall so i would like to put the screen on the oposite side of the room.
I guess i am looking for some suggestions on if the projector will shoot under the duct.
I hope this was clear, if not I will try to explain better or take some pics.
Jaritta
Harman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Screen Innovations Performance Series 110in
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Sonos-Amp, Connect, Play5
Post edited by jaritta on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2011
    Yeah, I think pics will be required. I'm having trouble picturing what you're talking about.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • jaritta
    jaritta Posts: 277
    edited January 2011
    Alright lets see if i can explain this better with pics.
    The two walls that are in the pictures are facing eachother in a relitivly square room. The door to the staircase is offset, as you can see in the pictures. I would like to put the projector flush on the ceiling(or close to flush) so it wont be in the way of people walking.
    Now, i would like to put the screen on the wall with the duct work running along it. The duct work will hang about 12in off of the celing after the framing and sheetrock is in place. I would like to put the projector about where the light bulb is. My question is will the projector immage miss the duct work if it is a flush mount or will i have to get an extension for the projector. If i did that i am afraid that it might hang too low and be in the way for taller people.
    I can put the screen on the oposite wall, but i plan to do a wet bar area just to the left of the pictures...again this is the wall with out the duct work running along it. And it would make more sense to have the wetbar next to the seating rather than the screen......
    So i am at the point of getting ready to run wire for speaker and projector hookups.....and a media cabnet so i need to get this figured out.
    I hope i was clear, if not, just yell at me and tell me to explain better
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • kuntasensei
    edited February 2011
    The 8700UB has a pretty good deal of lens shift (just under three picture heights), but if you mount it above where that duct work is, I'm not sure if you'll be able to get it down low enough (and the lower you get in the lens shift range, the more you increase chromatic aberrations caused by the lens). I would guess that you'd want to use an extension, though I wouldn't think you'd need much. Maybe just enough to bring the center line of the lens down to the bottom of that ductwork.
    You might throw your distances into the calculator over at projectorcentral.com and see if it might make more sense to shelf-mount the projector on the opposite wall instead of ceiling mounting. That way, no one could whack their head against it, and you could drop it down low enough to clear everything (and maybe go larger than 100" if you have to, though I wouldn't go too crazy).
    Equipment list:
    Emotiva XPA-3 amp
  • Ricardo
    Ricardo Posts: 10,634
    + 1 ^^^^^^
    If a ceiling extension puts it in the way of heads, shelf-mount it in the opposite wall.
    SOPA
  • jaritta
    jaritta Posts: 277
    Thanks for the ideas, i have gone to the projector calc and if i mount it on my back wall it is going to be very close to the max distance from the screne, plus i am concerned about the leingth of hdmi cable and if i will have any picture loss if i make a long run, my original idea was to put the componant cabnet in the right hand corner of the wall with the screne, this would probably be a 25ish foot hdmi, would i have any problem with that. I dont think it would take much of an extension to miss the duct....just thinking at this point.
    Also if i put it on the back wall would i have any problems with things like heads getting in the way of the picture??
    Thanks guys you have already been a huge help!
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Buy a mount with a drop tube
  • jaritta
    jaritta Posts: 277
    kind of the way i am leaning, any suggestions on type, also any suggestions on rear wall mounting shelv, do you have problems with things getting in the way of the picture if rear wall mounted?
    My celing will be just under 89ish inches if i get a tube mount i am afraid that it will hang too low because of the clearance below the duct work.
    The projector calc was good but again it doesnt help me with the throw of the projector.
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • Ricardo
    This is the shelf I used:
    http://www.amazon.com/gp/product/B001DMJ49C/ref=oss_product
    If someone stands up in the seating position, there will be a head in the screen. But that will also happen with ceiling mounted projectors.
    SOPA
  • kuntasensei
    As far as the length of HDMI... I'm using 35 ft. of HDMI from Monoprice.com with wall plates from my AVR to my Epson 8500UB, with about another 5-7 ft. from sources to AVR to plates. No signal issues whatsoever.
    Ricardo, I dig that shelf. I may have to swap my homemade wood shelf out for that, 'cause that looks NICE!
    Equipment list:
    Emotiva XPA-3 amp
  • Ricardo
    For $27 it is well worth the investment.
    I use a 50ft HDMI from monoprice. I use the $13 repeater, but I don't really think it is required.
    SOPA
  • polkfarmboy
    I was thinking about the monoprice big long hdmi cables ..are they any good ?
    I was lucky to buy a pj mount from elite screens that worked but it does not work with my epson but my epson pj has awesome lens shift . drop tube mounts are ugly but effective
  • kuntasensei
    Man, those long Monoprice cables are QUALITY. Thick as hell, well shielded, and I haven't had a single dropout (and I'm not using a repeater/amp for that length).
    Equipment list:
    Emotiva XPA-3 amp
  • jaritta
    jaritta Posts: 277
    There are a bunch of different types of long hdmi cables, i am looking at getting one, which type? most say standard speed...do i need a high speed. just fyi i am not getting 3d projector so does it matter?
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • Ricardo
    I got their professional 22 AWG standard speed cable. It works great for me (Epson 8100).
    SOPA
  • Dandydan
    Dandydan Posts: 21
    I also use a Monoprice 25 foot HDMI cable on my Epson 8700. Picture is unbelievable especially with BD played. Using 16:9 110 In. screen with 1.3 gain and a light controlled environment where I can make it black.
    The pop on the screen is as good as a plasma or LCD.:cool:
  • jaritta
    jaritta Posts: 277
    Dandydan wrote: »
    Dandydan,(or anybody else) What type of screen are you useing, I need to try to figure out what type of screen to use. A guy i was talking to said something about useing a blackout screen....I dont know if he made his own or what. Just looking to get some info on that also. I am also a little illaterate on what 1.3 gain is...could you please explain?
    Is it worth buildig your own screen or buying one? Also I am looking at a monoprice hdmi switcher with remote so i can switch hdmi signal because my avr is older and doesnt have hdmi, Is there anything i need to look for as far as specs?.....ect.
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • kuntasensei
    Cheap 100" 1.1 gain Elite Screen pulldown for me, but I have a strange placement (as you can see in my gallery).
    Equipment list:
    Emotiva XPA-3 amp
  • polkfarmboy
    Them cheap pulldown screens you mention has the best color accuracy out there next to the stuart firefox and the 1.1 gain does not hotspot
    I use an infocus hd grey screen because I sometimes have side lighting and its great for superbowl partys and stuff during the day
    So go for a grey if you cant completely block out the light and it will boost the native contrast as a bonus, but when its dark but you suffer from inacurite color compared to the white screens
    You can find a white or grey fixed frame from elite for only $250 on amazon usually 105 to 120 inch
  • kuntasensei
    BTW jaritta, you might find this interesting:
    "This Epson has plenty of lens shift too! For that same 100 inch screen, the Epson can be placed, (normal The Epson Home Cinema 8700UB projector lens shift.or inverted), anywhere from 22.7 inches above the top of the screen surface, all the way down to 22.7 inches below the bottom of the screen surface. That is measured from the center of the lens."
    So you might just be able to flush mount to clear that vent. Or at the very least, use a very short extension.
    Source: http://www.projectorreviews.com/epson/home-cinema-8700ub/tour.php
    Equipment list:
    Emotiva XPA-3 amp
  • Dandydan
    Dandydan Posts: 21
    Placement was no issue 12 feet from the screen - centered of coarse. Tons of adjustment room on a 6'8 in ceiling. I use on a 4 inch projector mount to keep it close. Gain compensates for lighter room conditions and brightens the picture slightly. I use it so i can run in eco mode and max. bulb life. Epson has a special on right now where they though in a few bulb with the purchase of the 8700. Just love the picture - I bought a no name electric screen Favi - and to be honest not sure if i could make it any better. All the reviews on the 8700 are true and then some as far as i am concerned. I was going to order a Panasonic AE4000 but when the new Epson was released they gave me a bulb / 100 rebate and reviews have been off the chart for image.
  • jaritta
    jaritta Posts: 277
    Thanks for all the answers guys. You have been very helpfull.
    Do you guys have any good websites to look at projector screens.?/Any suggestion on brands?
    Is it worth going cheap on a screen or droping 500-700+ on a screen when i am paying 2100 on the espon 8700, I guess i am afraid I am spending a lot on the projector and not getting its full potential because i am trying to be cheap on the screen.
    I am worried about getting the color ballance right on the 8700 when i get it. Do i need to get a calabration dvd? if so, any suggestions?
    Any suggestion on flush mount/tube mount projector celing mounts??
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • jaritta
    jaritta Posts: 277
    sorry i guess i should say i am looking at a fixed-mounted type screen, not the drop down type
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • polkfarmboy
    jaritta wrote: »
    Just look for an elite silver frame projection screen. they are tensioned fixed frame screens and come in a variatey of screen gains and available with grey or white
    The elite screens require almost nothing to calibrate them especialy with the new thx mode on the 8700
  • kuntasensei
    Yeah, the Epsons' out of the box performance is pretty much as close to pre-calibrated as you can get. If you have a blu-ray player, google "AVS 709 HD" and there's a free downloadable 1080p calibration disc that is invaluable. All you'd need to do color is the right blue filter... but I would honestly say that you're gonna be so happy with the 8700 in THX mode that you won't be too hung up on calibration.
    Equipment list:
    Emotiva XPA-3 amp
  • Ricardo
    www.Carada.com
    Not cheap, but it's an awesome screen. I got the precision bright white in 104" and it matches very well with my Epson. The gain really helps get a decent image with ambient lights, and I have not found any disadvantage to it. No matter where you are standing the picture is excellent.
    SOPA
  • jaritta
    jaritta Posts: 277
    Hey guys, here is a link to the screen that i am looking at....let me know if you were in my position would you buy this screen. The carada screen is awesome but a little more than i wanted to spend.
    Sorry to keep this thread alive, i just kind of have no idea on where to go on the whole screen issue.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190496163833&category=48655&_trksid=p5197.c0.m619
    here is a link to the screens in use.
    http://www.smugmug.com/gallery/7680380_sAijF/1/496001832_4zExy#496001832_4zExy
    I dont know...maby i should just break down and buy the carada screen
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • polkfarmboy
    Well here is somthing to put in perspective
    In audio always invest heavily in speakers and amps because cdp's and pre's change and get changed out alot
    For video you should invest heavily in your screen because projectors and av processors change and get changed out alot too
  • Ricardo
    I would go with Carada. I couldn't be happier wity mine.
    Maybe that ebay screen is great. Maybe it isn't. But a gain of 1.0 might be too low for ambient light watching.
    SOPA
  • jaritta
    jaritta Posts: 277
    Alright, i think youve convinced me, i think i will break down and buy the carada :)
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • jaritta
    jaritta Posts: 277
    Hey guys, i have another quick question, I have an xbox 360 that i want to conect to the projector, should I get the 25ft componant video cables and couple them to the componants from the 360, should i get a cable from monoprice that has componant on one end and vga on the other.
    The componant-vga is about 6.50 vs the componant-componant is about 20ish.
    Can i pass the same quality of video to the projector via the vga or is the componant-componant the only way i can pass 1080p to the projector
    I guess i should mention that the xbox is an older one that doesnt have hdmi(thanks microsoft....that was a brillant idea)
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
