Rookie setup for new surround sound
Great site long time looker first time poster. Don't laugh at my setup but i have a avr254 receiver, cs1 center, monitor 50's front, r300 rear and psw505 sub. when i run the auto ez/eq setup on my receiver it sets everything to large? is that what i would want? what you you guys set the speakers up manually at?
welcome to club polk....
I've been looking at the HK AVR 254. so i'm not laughing. Let me know how it turns out.
-- wayne --Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Set all your speakers to Small. After the automatic calibration go back in to see what the individual speaker settings are ( db ) you may find bringing them back to o db will help...or at least close to 0 db.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
How do you have this all wired up ? If the speakers are connected directly to the avr, and you use the sub out on the avr to go to the 505, then set all speakers to small,crossover in the receiver at around 80, and turn the crossover on the back of the sub all the way up to it's highest value. That should give you a good starting point.HT SYSTEM-
lsi 9's -
Ok, I did the avr254 easy eq setup with the mic. all the speakers are connected directly to the avr and the sub is lfe. The avr sets all my speakers to large is this the correct setting? Just doesn't seem like i should have my center on large too. hmmm??
menu doesn't allow me to set "small" it has settings for speakers :
center: Large, 40hz, 60hz, 80hz, 100hz and 120hz i believe.
mains: same settings as above
surrounds: same settings
sub: Present, 8 inch, 10 inch, 12 inch, 15 inch. -
How do you have this all wired up ? If the speakers are connected directly to the avr, and you use the sub out on the avr to go to the 505, then set all speakers to small,crossover in the receiver at around 80, and turn the crossover on the back of the sub all the way up to it's highest value. That should give you a good starting point.Ok, I did the avr254 easy eq setup with the mic. all the speakers are connected directly to the avr and the sub is lfe. The avr sets all my speakers to large is this the correct setting? Just doesn't seem like i should have my center on large too. hmmm??
Welcome to Club Pok jabbahoomenu doesn't allow me to set "small" it has settings for speakers :
Tony's bang on on the setting requirements. The reason the AVR sets the speakers all large is because it recognise them as being able to do so. However, for proper HT experience you must set them all up manually at 80Hz and let the sub provide for the bass. You definitely NEVER set a center large as it needs to concentrate on the movie voices which will play in the mid bass - 80Hz area (man's voice) up to the female voices (higher frequencies). Your fronts are capable of bass but you are better of to give the task to the 505 keeping your AVR power for the mid and high.
Cheers!
TKDARE TO SOAR:
ok, so just set all speakers to 80hz and call it good?
Thanks. -
yup, that should do the trrick.Main System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Receiver: Pioneer VSX-1121k
Amp: Carver AV 705x
TV: Samsung LN52A650
Media Player: Chromecast/Boxee Box
BD Player: Sony BDP-S470
Consoles: Xbox360, Wii U
