Rookie setup for new surround sound
jabbahoo
jabbahoo Posts: 4
edited January 2011 in Speakers
Great site long time looker first time poster. Don't laugh at my setup but i have a avr254 receiver, cs1 center, monitor 50's front, r300 rear and psw505 sub. when i run the auto ez/eq setup on my receiver it sets everything to large? is that what i would want? what you you guys set the speakers up manually at?
Post edited by jabbahoo on
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2011
    welcome to club polk....
    I've been looking at the HK AVR 254. so i'm not laughing. Let me know how it turns out.
    -- wayne --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • larry777
    larry777 Posts: 480
    edited January 2011
    Set all your speakers to Small. After the automatic calibration go back in to see what the individual speaker settings are ( db ) you may find bringing them back to o db will help...or at least close to 0 db.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    edited January 2011
    How do you have this all wired up ? If the speakers are connected directly to the avr, and you use the sub out on the avr to go to the 505, then set all speakers to small,crossover in the receiver at around 80, and turn the crossover on the back of the sub all the way up to it's highest value. That should give you a good starting point.
  • jabbahoo
    jabbahoo Posts: 4
    edited January 2011
    Ok, I did the avr254 easy eq setup with the mic. all the speakers are connected directly to the avr and the sub is lfe. The avr sets all my speakers to large is this the correct setting? Just doesn't seem like i should have my center on large too. hmmm??
  • jabbahoo
    jabbahoo Posts: 4
    edited January 2011
    menu doesn't allow me to set "small" it has settings for speakers :
    center: Large, 40hz, 60hz, 80hz, 100hz and 120hz i believe.
    mains: same settings as above
    surrounds: same settings
    sub: Present, 8 inch, 10 inch, 12 inch, 15 inch.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2011
    tonyb wrote: »
    jabbahoo wrote: »
    jabbahoo wrote: »
    Welcome to Club Pok jabbahoo :smile: Tony's bang on on the setting requirements. The reason the AVR sets the speakers all large is because it recognise them as being able to do so. However, for proper HT experience you must set them all up manually at 80Hz and let the sub provide for the bass. You definitely NEVER set a center large as it needs to concentrate on the movie voices which will play in the mid bass - 80Hz area (man's voice) up to the female voices (higher frequencies). Your fronts are capable of bass but you are better of to give the task to the 505 keeping your AVR power for the mid and high.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • jabbahoo
    jabbahoo Posts: 4
    edited January 2011
    ok, so just set all speakers to 80hz and call it good?
    Thanks.
  • cascius
    cascius Posts: 179
    edited January 2011
    yup, that should do the trrick.
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Receiver: Pioneer VSX-1121k
    Amp: Carver AV 705x
    TV: Samsung LN52A650
    Media Player: Chromecast/Boxee Box
    BD Player: Sony BDP-S470
    Consoles: Xbox360, Wii U
