power cable upgrade
samnor
samnor Posts: 155
I've just gone down the path of upgrading my power cables in my system (added a pangea ac9 for my parasound hca 1500 amp, and a pangea ac14 for my oppo dv981 which I'm using as the preamp). Definitely am a believer in the improvement from the cords. I just picked up a signal cable magic power cord.
At the moment, I have two possible places to try the cord. From my wall outlet to the rotel power conditioner (to which the parasound is hooked up) or to my subwoofer to replace a decent 14awg power cord that I replaced the stock with). Any suggestions on which would be a better place. My gut says the rotel. Just wanted to hear some feedback. Thanks.
Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup
Post edited by samnor on
  • Conradicles
    Conradicles Posts: 6,400
    edited January 2011
    I say the Rotel power conditioner. I just added a PS Audio xStream Plus 8 gauge power cable for my conditioner in my 2-channel system. Seems like a great place to start.
    Maybe do a test on each to see if you can tell which spot is better in your rig.
    edited January 2011
    Put it on the sub, I used the exact cord on my SRT subs with good results.
  • samnor
    samnor Posts: 155
    edited January 2011
    thinking thru this a bit more, I guess the rotel shd be doing some amount of power/noise cleanup which normally would be the burden of the cord, so I am now thinking maybe a a better bang for the buck would be on the lines of Tonyb's suggestion of trying it on the sub since that is going to the wall outlet via a surge strip (no noise cleanup there).
  • samnor
    samnor Posts: 155
    edited January 2011
    Thanks for the suggestion. not much money left over right now but I've read many good things about MIT,shunyata and also signal/pangea on the budget front. For now, I am just starting to find my way about in the cable upgrade area and from what I hear, signal and pangea are decent entry level cords. certainly will consider the MITs as I slowly move up the chain. Still have to save money for a basement finishing so that I can move the whole 5.1 rig out to a dedicated room.
  • samnor
    samnor Posts: 155
    edited January 2011
    Lasareath wrote: »
    If you ever get the chance pick up some MIT power cords. I have 3 and I love them. The best I've tried so far.
    something like this, but this one is too high, you can get them used for around $85 each
    http://cgi.ebay.com/High-End-MIT-Z-Cord-II-AC-Audio-Power-Cord-2m-/150551408547?pt=LH_DefaultDomain_0&hash=item230d902fa3
    so where would you put the MIT cord if you only had one as per my original post?
