cleaning lubing surrounds on sda2bs
scottyboy76
just got these, bless you jerryj12, was wondering should i clean, lube surrounds, if so with what.
humpty dumpty was pushed
Post edited by scottyboy76 on
KY His & Hers....
It will increase both of your's pleasure
\I'm Just Sayin/
-- wayne --Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Im new to this sht, you will be responsible if i end up with greasy, low rent ron jeremy type sdas, im gullible when it comes to this. lolhumpty dumpty was pushed
scottyboy76 wrote: »Im new to this sht, you will be responsible if i end up with greasy, low rent ron jeremy type sdas, im gullible when it comes to this. lol
LMAO:biggrin:...TGIF
Sorry I don't have answer but that's funny2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Devil's spit.
Use Windex. Spray the rag and gently wipe the surrounds. That's all that should be done to them. Don't use anything to "lube " them such as Armor All. etc. as it will ruin them. Keep the covers on them.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Polkersince85 wrote: »Use Windex. Spray the rag and gently wipe the surrounds. That's all that should be done to them. Don't use anything to "lube " them such as Armor All. etc. as it will ruin them. Keep the covers on them.
The perfect answer.Political Correctness'.........defined
President of Club Polk -
Why would armor all do damage? It's supposed to be made to protect rubber, vinyl, plastic, etc from sun damage and keep it pliable.
The surrounds are made of butyl rubber so it seems like it would help keep them new.
Fred"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I have 30+ years old drivers that have never been touched and are as good as the day they were born. Treatments will ruin the elasticity of the rubber.>
The reason you Windex is good is that is leaves NO residue. If you use Armor or most any other 'protectant', it will leave a residue. The residue WILL attract dust, lint, etc. Just like Polkersince85, I have a pair of SRS that are 30+ and the surrounds are perfect - sturdy and seem to me to be as flexable as new.SDA SRS modded: Xovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDOd, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
I assume you would want to use Windex that is ammonia free ?Speakers: SDA-1C (most all the goodies)
Nah, the regular stuff.Political Correctness'.........defined
drumminman wrote: »
Fred
Armor All is the devil. It actually degrades rubber and plastics.Political Correctness'.........defined
I use this method with a lintless cloth and it works great. I never have the covers on mine though...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
