Polks new sub?!
Ericw2431
Ericw2431 Posts: 228
edited January 2011 in Speakers
DSWPRO660wi<
looks like its better than the pro600?! but why is it cheaper?! look at the specs somebody fill me in on what im missing!:confused:
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Post edited by Ericw2431 on
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    It's wireless.
    Main Surround -
  • Ericw2431
    edited January 2011
    ?! Apperently but being wireless does it affect any in response?! i see its rated down to 20hz and rms is higher than the pro600?! shuldnt it be a better subwoofer?!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • Topper
    Topper Posts: 403
    edited January 2011
    wireless on these new subs is lossless so there shouldnt be any negative affect whatsoever.
    (i'm very familiar with the wireless Polk PSWi225 and the wireless performance on that sub was shockingly good. never got it to loose connection or anything)
    edited January 2011
    It pretty much looks like the same sub as the 600 with the main difference being WIRELESS capability and a doubling of the wattage from 250 to 500 watts continuous. Which is a GOOD thing.
    As for the frequency response. There is NO change. The 600 and the 660 both have a REAL low end of 25hx +/-3db.
    The lower price, is NICE though!!
    cnh
  • Ericw2431
    edited January 2011
    yeh i was actually thinking of buy a 2nd sub shuld i get the wirless 660?! or klipsch sub 12?! bic pl200?! please help i want more bass not just a 6db change! atleast 10db! =]
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2011
    I'm not sure which one has better specs or you would prefer, but since you mentioned the Klipsch Sub 12 I noticed that is currently in the shell shocker deal section of NewEgg for 239.99 if it makes a diff to your choice. Good luck in your search.
    edited January 2011
    That's a great price on the SUB-12 but it can't really compete, 'musically', with the Polk DSW above. Klipsch subs have sloppy bass--though good low thump output?
    cnh
  • Ericw2431
    edited January 2011
    yes as dough i have the polk psw505 for that can i really hear the diffrence and is it any louder?! will me getting the wireless 660 or 600 make any diffrence in DB mesured in the room by that i mean any more hits to my chest louder should i say!....??
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
