Made some DIY Stands...
Conradicles
With some scrap steel from work and the help of a friend, these stands turned out pretty sweet.
26" tall with spikes, all steel construction and the steel column will be filled with sand. Still need to add some little rubber pads for the speakers to rest on at the top plate.
Talk about heavy! They will hold up my new LSi9's in the man cave...:cool:
Post edited by Conradicles on
Looks good.
Blu tack works well too.Conradicles wrote: »Still need to add some little rubber pads for the speakers to rest on at the top plate."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
those do look good, nice jobDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Those look great!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Those look very nice!--Gary--
Those look great, nice work!2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Nice
Ben -
They look great, look just as good as the one you pay the big bucks for...DARE TO SOAR:
looks great... need a matching set for the brewskees! :biggrin:Yamaha rx-a2000 AVR
Polk csi5 Center
Polk rt16 Main
Polk fxia6 Rear Surround
Paradigm Micro Rear Back
Onkyo bookshelf Front Presence (for now)
PSW 450 Front Sub
DSW MicroPro 4000 Front Sub
DSW MicroPro 2000 Rear Sub
Samsung c6300 60 inch LED
Sony BDPs370
Room Size 15x30 -
very nice... will be hard to knock those over for sure .
Nice!!
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Wow, they look store bought.
Hmmmm, I'm kind of envious. Post more pics when the LSi9's are sitting on them.
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Those are pretty cool. I like the spikes.
Very nice, did you weld those yourself? As for the sand, are we talking course or fine sand
HT:
TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs -
Pic's as requested...
These were actually not welded Zaigrith, but attached together with hardware. No sand yet, and actually I'm thinking of something different than sand. -
Very nice, how heavy are they?
I recently built a 26" pair using 3" PVC tubes. When fully filled with sand they weigh 18 lbs each. Fit and finish are seriously lacking but they get the job done. But if I had to do it over again I'd go with 4" tubes for more mass-loading capability and a larger top shelf that can accommodate the entire length and width of the bookshelf. -
I'd say they weight about 35 LBS each now, but when I add some shot or something similar maybe around the 60 - 70 LB range.
wow i need to build me a pair of those!
They look great man!- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
