Does speaker wire length matter ?
larry777
larry777 Posts: 480
I am going to order some 12 Gauge speaker wire and have to deterine how much I will need. I read an article that the length of your wire should be all the same for each speaker. The farthest distance to my Back Surrounds will be aprox 35 ft....due to going along a couple of walls at floor level before getting to the speaker etc. My front 3 lets say would only need 7 ft of length. Based on this article I would need 35 ft x 7 for my speaker setup. IS This True ?.... Or can I go say 2 X 35 Ft Rear Surrounds....2 X 25 FT Side Surrounds.......and 3 X 7 Ft for the Front ( L,R & C ). Less speaker wire will save me money especially shipping costs from USA to Canada. The point of the Article was that the Audio Signal would reach all your speakers at the same time if the speaker wire was the same length,and therefor give a better sound overall.
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Post edited by larry777 on
«134
  • JuanR
    JuanR Posts: 718
    edited January 2011
    Nobody I know does the same length all across the board, thats silly. If someone can argue that the same length speaker wire is required for a 5 channel system, then I would recommend you not read any more of their advice.
  • mantis
    mantis Posts: 17,487
    edited January 2011
    15 gauge wire is all that is required for the lengths you are running. No all wires don't need to be the same length.
    I'm kinda anal about wiring and I make my front 3 the same length if it makes sense. At least the front left and right. Center channel is less important to me as I like to double duty my system for 2 channel and theater. Rear channel wiring is what length it is to get to them. The speed the signal travels down the wire isn't a factor at those lengths.
    Dan
  • Outfitter03
    Outfitter03 Posts: 563
    edited January 2011
    A legitimate reason to have your lengths match is resale value when using nicer cables. Just like trying to buy or sell a pair of shoes when you have one size 8 and another 10, this will only fit a small group of people.
    So once you decide to go to nicer cables, it is best to get equal lengths. Because of an entertainment center, I need one meter on the left side and 2.5 meters on the right in front.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2011
    Just use the length you need for each speaker, don't worry about any of them being the same length, at those lengths, it won't make an audible difference.
    pitdogg2 Posts: 27,079
    edited January 2011
    not to mention if you took that 35' of cable for the front speaker thats 8' away and wound it all up behind your speaker you're basically making an inductor behind your speaker. Which could in theory suck out some frequencies
  • angelsfann02
    angelsfann02 Posts: 589
    edited January 2011
    If getting a good deal on speaker cable is an issue, and you need various lengths, then try Monoprice.com
    I dont know if they ship to Canada. One 100ft. roll will suit you. I am with everyone else when they say that the speaker lengths are unimportant. I matched the speaker lengths on my fronts and center because they were pretty much equal distance from my amp. My surrounds are different distances from my amp and therefore I used different lenghts. I think 12 gauge is kinda thick for surrounds ( I used 16) but its your choice. Good luck.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • JimAckley
    JimAckley Posts: 1,138
    edited January 2011
    From what I've read, use equal lengths for each pair of speakers. e.g. 20 ft to each of your surrounds, 7 to each of your fronts, etc. I switched from crap wire to Monster Cable XP and made sure my surrounds both had the same length and all of my fronts have about 7 ft. If you have extra wire to a speaker, wind it in a figure 8 to avoid making a big coil. It's not perfect, but it's better than looping it in a big circle.
    I agree with angelsfann02 in the fact that 12 gauge is pretty overkill, unless you're running a high powered amplifier. And if you were already up to that level of HT, you probably wouldn't be asking us this :P I'm not sure if there are RadioShacks in Canada, but if there is, stop by your local store and pick up the Monster Cable XP-Ci 100ft spool. Most stores here in the US have it in stock but on clearance for $39.97 USD.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • larry777
    larry777 Posts: 480
    edited January 2011
    Thanks for all the responses. These comments answered all my concerns about speaker wire length. I am looking at 12 Guage wire, as that was the recommendation from another recent post I started. I may add an amp to my system later on as well.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • crazytasty
    crazytasty Posts: 18
    edited February 2011
    I wonder how much of a difference there is in audio quality if a very long wire is used, anybody know?
  • Cayuga
    Cayuga Posts: 480
    Get 16 guage and saave your money for an amp down the road.
    F1nut Posts: 51,817
    Use the 12 gauge, there's no such thing as overkill in this hobby.
    True that is why i run 10ga. even on the short center channel 4' length.
    :wink:
  • ben62670
    ben62670 Posts: 15,969
    Only if you coiled it. Keep in mind the extra capacitance of the longer cable to the shorter cable, and also resale value. Two long runs can be made into 4 runs if you wanted to upgrade again, or move your gear around.
    Ben
    ben62670 wrote: »
    very true Ben but most folks i know do coil it up like a cowboys rope ...you know so it looks neat in case anybody looks behind the speaker ie: the wife:redface:
  • Ralphdole
    Ralphdole Posts: 3
    It doesn't matter how long your wire is, you just have to set up the delays for the speakers that are closer to most stereos will do it just by setting up the distance of the speakers in the set up menu.
  • Theheadsn
    Theheadsn Posts: 413
    edited March 2011
    Good to know this stuff, what a wonder the search button does.
    Im gonna need all different lengths so its good to know I wont be **** myself.
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited March 2011
    I'm using different lengths, but each rear and surround pair has wires of about the same length. My mains are 6', and the center is 3'.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • gmm141
    gmm141 Posts: 29
    edited March 2011
    I always adhered to the theory of using the same length for each pair (plus it pacified my OCD) ...but that habit formed before AVR's had the sophisticated setup programs that they do now.
    That's what I have stuck to with good results in both my family room and HT.
    Display: Panasonic 54VT25 3D Plasma
    Receiver: Pioneer Elite VSX-32
    BluRay: Panasonic freebee w/ TV
    Fronts: Polk LSi15's
    Front High: LC65i's
    Center: LSiC
    Surround: LC65i's
    Surround Backs: LC65fx's
    Sub: Old (but surprisingly not tired) Infinity
  • Theheadsn
    edited March 2011
    Yea im torn, because potentially my rears would be almost 50 feet for one, and 26 feet for the other. Dont know if I want an extra 24 feet of wire just sitting there
    Home Theater Setup
    • Sub - SVS PC-4000
  • John K.
    John K. Posts: 822
    edited March 2011
    There's no need for the wire lengths to be equal, and the automatic calibration for delays which most receivers have these days has nothing to do with it. The electromagnetic wave carrying the voltage and sound signals travels down the outside surface of the wire at about 3/4ths the speed of light(say about 700,000,000 feet per second). The "delay" involved at home distances is under a millionth of a second.
  • ben62670
    edited March 2011
    I wasn't referring to the speed of electricity.
    Ben
  • Mr Glide
    Mr Glide Posts: 29
    edited March 2011
    larry777 wrote: »
    Can you please point me to that article? Thanks.
  • allstock
    allstock Posts: 136
    edited March 2011
    xcapri79 wrote: »
    The following guide by Roger Russell is one of the best to steer you in the right direction regarding speaker cables. It has served me and others in this hobby very well. Not everyone agrees with it, but everyone can't always agree on everything.
    You will note that the length and gauge used is dependent on speaker impedance.
    http://www.roger-russell.com/wire/wire.htm
    Oh Jesus, here we go....:rolleyes:
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
  • ben62670
    edited March 2011
    The next person that posts the miss information presented by RR is going to get a virtual slap.
    Ben
  • camp21178
    camp21178 Posts: 273
    edited March 2011
    I always enjoyed the Roger Russel articles. He certainly has some great credentials. It's always nice to get all sides of an issue.
  • ben62670
    edited March 2011
    So camp please tell all the fine folks here at Club Polk your vast experiences with different gear and cables. Use your ears.
    *SLAP*
    Ben
  • polkskier
    polkskier Posts: 6
    edited March 2011
    I'm very new to all this. I stumbled across the roger russel arcticles recently. To my novice mind it seemed to make sense. Maybe I just wanted it to since it would mean I could spend more on speakers and less on wiring. What is wrong with what he's saying? Where can I find more accurate info. Not trying to start an argument, just genuinely want to learn. Thanks guys.
  • John K.
    John K. Posts: 822
    edited March 2011
    Skier, welcome to Club Polk. I see that this thread where I previously posted a presumably clearly-established technical point, has new life on an unfortunately contentious matter. Mr. Russell's explanation of the facts regarding speaker wire is undoubtedly the most cited on the internet and has helped numerous new listeners over the past few years to avoid the wire scams which pollute our hobby.
    What he sets out isn't his personal work alone, but simply is basic audio technology of how connecting wires work in action. Contrary claims abound, but these have failed to pass the (double blind listening)test. When "believers"(a rather inappropriate term, since audio equipment is technology, not theology)have this brought up to them , reactions sometimes are crude or occasionally even profane. You can get a concise summary of why such feelings arise by reading the final paragraph in the "Big Picture" section here .
    Use your money for things that make a difference and deal with high-quality, low-cost providers such as MonoPrice and the Tartan Cable division of Blue Jeans Cable for your wire and cable needs.
  • ben62670
    edited March 2011
    polkskier wrote: »
    It's real simple. Try some good wire against some crap wire. Buy the good wire used so if you do not hear a difference you can sell it with no loss, or even a gain. Also see if there are any Polkies near by. Let them demo for you. This is how I learned about the difference good wire can make. I used to believe like John does, but I actually used my ears to decide. I wish it didn't make such a difference. I don't make the kind of money that I can just go out and buy expensive gear. If it didn't make a difference I would not have "wasted" my hard to come by money on better cables.
    Ben
    Ben
    F1nut Posts: 51,817
    edited March 2011
    John K. wrote: »
    blah
    Stop picking on the new guys. Not everyone wants to wallow in the depths of low-fi as you do.
