Subwoofer vs. Subwoofer
tavogee
tavogee Posts: 91
Would it be allright to run two different brands of subwoofers on my 7.2 system? I haven,t purchased my second yet, but am curious of this. ! ANYONE!
LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
Post edited by tavogee on
    EndersShadow Posts: 17,722
    edited January 2011
    it has been done, however since they both may not reproduce the same frequencies and or have the same wattage it could be more trouble than its worth to get them both to blend together.
  • Geoff4rfc
    Geoff4rfc Posts: 2,961
    edited January 2011
    tavogee wrote: »
    I've done it for a year now, Onkyo sub from the SKS-HT870 system and an Energy 200watt sub, with similar volume settings and EQ, the blend was decent.
    I am however upgrading to some serious sub, I'm x-ing to two priors and replacing them with an Epik Empire.
  • spock 2054
    spock 2054 Posts: 163
    edited January 2011
    Been running a Velodyne DPS-12 in tandem with an Infinity PS210 for almost a year on an Onkyo 806. Wish I had room for an Epik...What are you using for a receiver? If you have an avr with Audyssey, there are some great tips for balancing multiple subs here:
    http://www.avsforum.com/avs-vb/showthread.php?p=14456895#post14456895
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • Geoff4rfc
    edited January 2011
    spock 2054 wrote: »
    Are you asking me? Onkyo 807, it does come with audyssey.
  • tavogee
    tavogee Posts: 91
    edited January 2011
    DIDN'T KNOW IF YOU WERE ASKING ME. I HAVE AN ONKYO TX-NR808. MY 806 WENT SOUTH ON ME AFTER 2 YEARS (left channels stopped working). FOR WHATEVER REASON IT ONLY WORKED IN FULL MONO.
