Subwoofer vs. Subwoofer
tavogee
Would it be allright to run two different brands of subwoofers on my 7.2 system? I haven,t purchased my second yet, but am curious of this. ! ANYONE!
LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
Post edited by tavogee on
it has been done, however since they both may not reproduce the same frequencies and or have the same wattage it could be more trouble than its worth to get them both to blend together."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I've done it for a year now, Onkyo sub from the SKS-HT870 system and an Energy 200watt sub, with similar volume settings and EQ, the blend was decent.
I am however upgrading to some serious sub, I'm x-ing to two priors and replacing them with an Epik Empire.Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Been running a Velodyne DPS-12 in tandem with an Infinity PS210 for almost a year on an Onkyo 806. Wish I had room for an Epik...What are you using for a receiver? If you have an avr with Audyssey, there are some great tips for balancing multiple subs here:
http://www.avsforum.com/avs-vb/showthread.php?p=14456895#post14456895polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
spock 2054 wrote: »Been running a Velodyne DPS-12 in tandem with an Infinity PS210 for almost a year on an Onkyo 806. Wish I had room for an Epik...What are you using for a receiver? If you have an avr with Audyssey, there are some great tips for balancing multiple subs here:
Are you asking me? Onkyo 807, it does come with audyssey.Set up:
DIDN'T KNOW IF YOU WERE ASKING ME. I HAVE AN ONKYO TX-NR808. MY 806 WENT SOUTH ON ME AFTER 2 YEARS (left channels stopped working). FOR WHATEVER REASON IT ONLY WORKED IN FULL MONO.LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
