Soundbar 360 no response remote no sound
Davecarp
Davecarp Posts: 2
edited January 2011 in Troubleshooting
Following a Wii usage on aux1, SB360 will not respond to the remote other than to show Polk Audio on display. Will not respond to remote changing the input to cbl/sat etc. Manually will not open DVD drawer, or respond to anything other than power on. Ideas?
Post edited by Davecarp on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2011
    Hello,
    Sorry you're having a problem. I may be a little rusty on this product, it's been a while since I've worked with one. Try removing the control box's AC power cord from the wall outlet, let it sit unplugged for a few minutes and re-plug it in the wall outlet. See if this resets the control unit.
    Regards, Ken
  • Davecarp
    Davecarp Posts: 2
    edited January 2011
    Tried that...did not help.any other ideas?
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    Call polk customer support tomorrow morning, they will help you out.
    Main Surround -
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2011
    Ken, didn't this one have a 'hard reset' button on the rear? I remember mine having this issue a couple times, but I can't remember if it was just a hard power cycle like you suggested or not to fix it.
