RCA connection or Polk's Reco?
cwmcln
cwmcln Posts: 1
Hello,
I've just bought my first home theatre and opening up the instructions to my sub has confused me big time.
I THOUGHT i would connect my Sub using a Monster 300 subwoofer interconnect but Polk recommends i run my front L & Rs through the sub with speaker wire.
SO which is best?
My components are below.
Thanks,
Court.
Receiver - Yamaha RXV 740
Speakers - RM6700s
Sub Woofer - PSW 303
Post edited by cwmcln on
  • dorokusai
    dorokusai Posts: 25,640
    edited February 2004
    The original idea you had is perfect for your application. Use the MC M300 Interconnect to connect your subwoofer to the AVR.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Make sure to use the LFE connection on the 303 and select the highest xo frequency the Yammy allows (hopefully around 120-150 Hz).
    Set the sub level to -5 on the Yammy and adjust the subwoofer volume at the 303.
    SVS
